Old 03-28-2008, 12:41 PM
Insano Insano is offline
Default Need Help for Icon D-Command!
Hi all,
Im the owner of an Icon D-Command 24 faders and i have some problems with my setup.
1. Can i use external outboard (EQ, Compressors, FX Units, etc) with my D-Command? If yes, how?
2. How i can connect a personal headphone mixer for each musician in my live room from D-Commands cue outputs?
3. Buying a D-Control will solve these problems?
Please help me out here!
Old 03-28-2008, 05:56 PM
Drew Mazurek's Avatar
Default Re: Need Help for Icon D-Command!
IMO these are fundamental things that go beyond the scope of this forum. I'd see your dealer and/or hire a professional engineer/technician to help you get these things set up.
Having said that:
#1 Yes, they will connect to your interfaces and PT will utilize them as either hardware inserts or Aux Sends. This can be done regardless of the D Command.
#2 You'll only use the Cue out of the D Command for part of this setup. Say input 1 and 2 to be used when all you need is a stereo mix and more importantly to get talkback into the Aviom (or whatever you're using)
#3 D Control doesn't specifically solve any of these issues over a D Command.
www.drewmazurek.com
Old 03-28-2008, 06:05 PM
digimidi's Avatar
digimidi digimidi is offline
[QUOTE]
Hi all,
Yes you can. All of your outboard gear should be connected to your HD interfaces (192, 96, etc) and then you can insert them under the I/O inserts just as you would plug ins.
If you are going to use a personal headphone mixing system, you will need to bus send on an interface output each instrument or group of instruments from Pro Tools. You will also want to send one of the Cue outs from X-Mon to the headphone system as well for talkback. You will set the sends to pre fader and probably unity so the talent can set their headphone mix the way they want. Depending on the headphone system, the sends could be either analog or digital.
The same instructions apply to both D-Command and D-Control.
For more information on how to set up your system, visit ICON All Access and download the tutorial files for D-Command. They should give you some guidance.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 03-29-2008, 06:20 AM
Thank you for your help!
I appreciate that!!
ICON D-Command not getting recognized in PT 11 kdramsey ICON & C|24 9 12-19-2017 07:12 PM
Icon D-Command Cue Monitoring Issues elankf1 ICON & C|24 19 11-27-2017 01:33 PM
Icon D-Command Questions DezMented ICON & C|24 2 03-31-2006 04:25 AM
ICON D-Command Steve White Pro Tools TDM Systems (Mac) 2 03-30-2006 03:22 PM
Icon D-Command ?? cachemira Pro Tools TDM Systems (Mac) 4 04-05-2005 02:47 PM
