Old 10-18-2021, 09:32 AM
subwoof subwoof is offline
Default Soundminer
This is a weird one... Of the 300,000 or so sounds in Soundminer, I have one set of sounds that show up, but won't audition. I can transfer them to Pro Tools just fine, but they won't play in SM. I've tried deleting the sounds from the database and then reimporting them. I can successfully play them directly in Quick Time. They are sounds I recorded some years ago, and use to work just fine in SM. Any ideas?
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 10-18-2021, 12:46 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Soundminer
Did you try to mirror those files with the Soundminer (to .WAV) files and then add them to the database?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 10-18-2021, 03:26 PM
minister's Avatar
minister minister is offline
I would delete the entire database. Create a new one, and rescan all your sounds. It doesn't take all that long. I've had to do it and I also have 100's of thousands of sounds.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-18-2021, 03:48 PM
Cheesehead Cheesehead is offline
Have you asked Justin about it directly?
I'm sure he could solve it for you Mike.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 10-19-2021, 01:12 AM
Sonopolis Sonopolis is offline
I had the exact same issue with one sound file. Justin confirmed that it was a a bug. I think an update to the latest beta solved it.
Old 10-19-2021, 01:48 PM
garret garret is offline
Are they Wav files or a different format?
IMDB
Old 10-22-2021, 02:58 AM
Yes, mine was.
Old 10-28-2021, 12:52 PM
Thanks for the suggestions. I have emailed support and am waiting for a reply. I'll let you know what I discover.
Old 10-29-2021, 09:49 AM
Default Re: Soundminer resolved
It turns out that the channel layout setting on those files had been changed to s. Once I deleted the s setting to blank, they worked fine. How they got that way I have no idea! Thanks everyone for your suggestions.
HTML code is On
WTB: Soundminer v4.5 Standard or Soundminer HD Plus Oliver M Buy & Sell 0 12-21-2014 01:50 PM
wtb: Soundminer Pro yazoo Buy & Sell 0 10-13-2014 04:53 PM
Soundminer HD vs. V4 icenet Post - Surround - Video 6 10-13-2012 03:00 PM
SoundMiner for PC? MGagnon General Discussion 2 09-01-2003 09:31 AM
