Old 08-02-2018, 10:41 AM
Default Re: German and De-Essing
I like Res-Desser best for notching, which a lot of the other plugs don't have. The Isotope Spectral Desser, in Spectral mode, not Classic, can do interesting things (listen to the side chain in this mode, it won't be what you expect), but it is a huge CPU hog. TDR Nova is a free dynamic EQ that I've come to like a lot. Hope that helps.
Scott Gatteño
Old 08-22-2018, 12:19 AM
Basstian Basstian is offline
the metric halo de-esser works pretty decent on german dialog. the problem is that you have to solve the problem during recording in the first place.
using schoeps mics and bigger distances than you would be used to ist a good starting point. but if the issue already persists. metric halos de-esser and some static eq dip in the 6 k range is your way to go.
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5
Mac OS 10.15.7
ProTools Ultimate 2020.11
Video Slave 4.3.477
Old 08-22-2018, 01:00 PM
Originally Posted by Reckless Erik View Post
Forgive my asssstonishment Scotty. Are you using 3 De-ess plugins at the same time on your DX?
I somehow missed this post when you first posted it. I think I may have misspoke when I said "a combination of". Perhaps I should have said "any of the following". I definitely don't usually use 3 de-essers on DX. I have definitely used 2, though not a normal practice. One in split/hi-shelf mode for "Ess's" and one in notch and at a lower frequency for "Ch's". That being said, I've received some pretty horrendous DX recordings in the past, and I'll do whatever I need to do to make it sound the best I can.
Scott Gatteño
Old 08-25-2018, 11:59 PM
critictalk critictalk is offline
Sometimes too much compression will bring up too much sss too. Just be careful.
HTML code is On
Help: Logickeyboard german, Win7 german, PT english -> wrong shortcuts joachim Tips & Tricks 9 09-11-2014 02:09 PM
De-Essing......where in the chain? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-27-2013 08:45 AM
De-essing Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2004 09:34 AM
De-essing Vocals skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2004 01:11 PM
De-essing With Digi???? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-25-2002 11:17 AM
