Old 08-12-2018, 12:21 PM
jjnssn jjnssn is offline
Default EuCon 2108.3 not seeing devices on Mac
2018.3 working on PC.
I have reload EuCon app. Verified subnet of devices is same for my MBP. Running OSX 10.13.3.
It has worked in the past.
Nothing showing in “all surfaces”.
Curious if there is something obvious I am missing.
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / TB3 AIC
PT12.8.2 HDX1 / Eucon 3.7 / OMNI / HD IO 16x16 / DIGIGRID DLS IO mode / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &
8 Thunderbolt
Late 2013 10.13 MacBook Pro
Old Yesterday, 06:35 PM
EddieJones's Avatar
Default Re: EuCon 2108.3 not seeing devices on Mac
Check EUCON Prefs network adapter setting
try turning off the firewall to see if that helps
Uninstall checking the remove everything box and reinstall
Always restart EUCON after making network changes
Old Yesterday, 09:40 PM
Thanks Eddie.
I had done the uninstall reinstall. Firewall is off in system preferences. I’ll check the network adapter settings.
8 Thunderbolt
EuCon setup for several devices and workstations Mark Ziebarth Avid Pro Mixing General Discussion 3 08-19-2016 12:00 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
How Can I Prevent Others From Hijacking My Eucon Devices? Picture Start Artist Series 5 11-10-2015 05:56 PM
quested powered 2108's AmericanCheese General Discussion 2 02-11-2003 06:48 PM
Universal Audio 2108 mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-23-2002 11:02 AM
