Avid IO interface trim replacement
Hi everyone, I have one of my trims in the Avid IO interface that does not work, when I turn it up to calibrate the channel to -18 it does not respond.
I would like to know wich is the right model to substitute it. Thanks |
Re: Avid IO interface trim replacement
I wasn't able to see your account where your I/O was registered. Can you PM or Email me the Email you registered your I/O on and your I/O's serial number so we can check on this? Have you also tried checking with https://avidtech.my.salesforce-sites...roduct-Repairs for replacement parts? Thanks! ([email protected])
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
I've bought it second hand, I did not registered it. I also have 3 192 connected toghether with the IO, I'm using Pro tools ultimate hdx.
I've also called the phone number of the Italian repair but they only repair icon. I only need the exact model, I can change the trim with my tech, is not difficult. |
Anyone used TASKAM Model 12 or 16 as an interface? | robertguzzi | Third Party Interfaces | 0 | 07-10-2020 08:19 AM |
Avid's New Model Is What It Is | Barry Johns | Pro Tools 11 | 104 | 11-20-2014 06:26 PM |
Can you trim MIDI regions from inside the MIDI editor window? | emspace | Pro Tools M-Powered (Mac) | 0 | 07-06-2010 12:13 PM |
Wich mic model should I use???? | ESR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-07-2003 12:46 AM |
Wich mic's, wich preamp,... help please | zara | Tips & Tricks | 4 | 12-10-2001 04:42 AM |
