Old 12-21-2014, 11:54 PM
bigbuddy3 bigbuddy3 is offline
Default PT HD Native 11.3 "Waiting for the video engine to launch"
Video Files wont open, hangs at the end of progress bar "Waiting for the video engine to launch" If I hit cancel I can import audio, I have tried Importing with out audio as well
I have tried turning GPU off, as well as other Video Prefs
I did a clean install of PT, no change
Pt 10.3.9 All works great
Using H.264 QTs
HD Native Avid (NEW) 8x8x8
MAC Pro 5.1 16G Ram
OSX 10.8.5
PT11.3
PT10.3.9
Thanks
Old 12-22-2014, 12:17 AM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default Re: PT HD Native 11.3 "Waiting for the video engine to launch"
I would have tried:
Reboot.
Re-install PT 11.3.
Reboot.
Before launching PT, shut down any other applications running in the background.
Disable any external video peripherals in Pro Tools - only to use desktop video. Any changes?
For me 11.3 runs better than 11.2.2. But I had to change the driver for my video peripheral, Blackmagic Intensity Pro. Do you use any video cards for your picture?
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
Old 12-22-2014, 08:33 AM
stustan stustan is offline
I just had the same issue and followed a Moderators advice on a similar thread and had success:
Manually delete all of PT11.3 and it's components, then reinstall 11.3.
I am now up and running
Old 12-22-2014, 08:35 AM
Please ignore my outdated signature, updating now
Old 12-22-2014, 10:31 AM
I'm a A Quad Core MAC Pro
I did re-boot, and re-installed OS. I don't have an external Video card, just internal MAC Video card
I will try to manually remove 11.3 and re-install.
Do you have a link to the thread of which files to remove, Cant seem to locate it
I appreciate your help
Thanks
Old 12-22-2014, 11:15 AM
Avid Knowledge Base
How to manually uninstall Pro Tools 11
Last Updated : June 24, 2013
Products Affected : Pro_Tools_1_6
Pro Tools 11 on Mac does not include an uninstaller. Below documents how to manually trash items installed by Pro Tools 11. This should not need to be performed as there are no known problems with having these files on a system (with or without Pro Tools installed).
Move the following files to the trash to manually remove Pro Tools 11 completely from a Macintosh systems:
Mac HD/Applications/"Pro Tools"
Mac HD/Library/Audio/"MIDI Patch Names"
Mac HD/Library/Application Support/Propellerhead Software/"Rex"
Mac HD/Library/Application Support/Avid/"Audio"
The Audio folder contains: "Plug-In Settings", "Plug-Ins" and "Plug-Ins (Unused)
Old 12-24-2014, 02:09 AM
Deleting manually and reinstalling did NOT fix the Video problem, I went back to 11.2.1 and its now working, 11.3 dosen't work for me.
I don't use an external video card. Ill try 11.3 again to see if I can figure out whats going on. I might create a separate new boot drive and only install PT 11.3 (no 3rd plugs) or Pt10 and test
Old 12-25-2014, 08:34 PM
More Official News:
See if this helps:
http://avid.force.com/pkb/articles/T.../11-3-No-Video
Waiting for the Video Engine to launch nicolasvandooren Post - Surround - Video 8 02-09-2014 02:32 PM
"Waiting for the Video Engine to launch" error mrhood Post - Surround - Video 0 07-25-2013 01:28 AM
Can't import video "Avid engine not installed"??? garnoil Post - Surround - Video 9 10-08-2012 04:45 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
"Avid Video Engine Not Installed" trondned Post - Surround - Video 9 09-17-2009 02:43 PM
