Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 01-08-2019, 10:40 PM
whsi whsi is offline
Default Virtual Instrument cause Duet input latency soar
I have been using duet for 3 years.
But the input latency increases sharply just after I load some virtual instrument.
Both input and output latency of buffer size of 64 is about 3.0X ms.
After loading only one virtual instrument, especially sampler with some memory load, the input latency jump to over 7ms. The most extreme time it is higher than 14ms. But the output latency remains 3ms.
This is not caused by lack of memory. I am using the same pc, and the same VIs.
I have tried to reinstall all the versions of drivers, and update the firmware with no success to solve the issue.
Please help me.
Thanks
PS: my memory is 32GB, and os is Windows 10.
Old 01-08-2019, 11:28 PM
Southsidemusic's Avatar
Default Re: Virtual Instrument cause Duet input latency soar
Need more info here.
What plugins are causing these issues?
What hard drives and what PT version?
The more info the easier to assist.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-09-2019, 06:22 AM
The pt version is 12.
The VIs I notice the issue include vsl synchron piano, garrtian libraries, and kontakt libraries.
Old 01-09-2019, 07:49 AM
Please re-read my post if you want us to be able to assist.
Where are your sample libraries located?
How many drives do you have?
Models (SSD/spinners) ??
Speed of drives if spinners?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-09-2019, 09:58 AM
Thank you for your reply.
cpu: i7 4790k
mem: 32g
Libraries are in samsung 950 pro, m2 version, 1.6gb/s reading measured by samsung ssd tool.
There is another raid 0 drive, used to store project files.
Sorry for my English.
Old 01-09-2019, 10:20 AM
Your English is great so no worries there
I would guess that the plugins you posted are a bit of CPU hogs and need a larger buffer size. Also I never ever look at those cpu meters as it doesn’t do anything for us unless there is a huge issue that make me think of a bad plugin.
Have you double checked ALL the plugins as if you have old versions and or a few bad demo plugins even if not used at all can cause havoc on the CPU.
I would drag all of them to the unused folder and then put them back a few at a time and test the session before adding the next batch.
Also make sure you trashed preferences and databases and let PT re-read all the plugins again AFTER you done the look thru all the plugins making sure they are all 100% updated and demos thrown away.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
PT 12.8.2 Virtual Instrument latency [email protected] macOS 6 12-06-2017 07:59 PM
Virtual instrument latency -- not! DAWgEAR Pro Tools HDX & HD Native Systems (Win) 2 06-14-2013 10:48 AM
Virtual instrument latency problems!!!!! ScottFB Virtual Instruments 6 07-23-2007 09:22 AM
Low latency monitoring with virtual instrument... gitan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-03-2005 08:43 PM
virtual instrument latency joelsimone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2002 08:19 AM
