Old 02-20-2020, 11:17 AM
CEBeaudin CEBeaudin is offline
Default Recording simultaneously on two separate Hard Drive
HI! I was wondering if it was possible to record in pro tools on two separate hard drive the same material simultaneously?
Thanks
Old 02-20-2020, 01:58 PM
JingleDjango JingleDjango is offline
Default Re: Recording simultaneously on two separate Hard Drive
A RAID array:
https://www.pro-tools-expert.com/hom...explained.html
Old 02-21-2020, 08:51 AM
daeron80 daeron80 is offline
Setup/Disk Allocation. Check "Use round robin allocation for new tracks". Make two audio tracks for each input and mute one. The material will be recorded to two tracks which will be placed on different hard drives by round robin.
A simpler approach would be to record to a disk that is being backed up to a cloud service like Dropbox or Google Drive. Each audio file would begin backing up to the cloud as soon as you drop out of record.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Separate video hard drive Gohanto Post - Surround - Video 5 04-12-2011 10:00 PM
separate hard drive and other questions telstarstuff Pro Tools M-Powered (Win) 2 08-16-2009 11:23 AM
Separate Hard Drive vs. Partition joseph halloran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-09-2004 08:18 PM
Separate hard drive deafmute 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 02-28-2004 10:09 AM
should I use a separate hard drive for pro tools? imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-02-2001 11:36 PM
