Old 10-17-2017, 07:06 PM
unkJE's Avatar
unkJE unkJE is offline
Default Blue Cat's Plug'n Script 3.0 - export your creations as independent VST plug-ins
Today's email:
Dear Customer,
We are happy to announce Blue Cat's Plug'n Script 3.0, a new release of our audio and MIDI scripting plug-in, with a brand new user interface and the ability to export your creations as independent VST plug-ins (full change list below).
As a registered customer of the previous version of Blue Cat's Plug'n Script, we offer you to upgrade for 19 EUR or $19 US only (80% off, price including taxes).
Normal Price: (-20%) 99 EUR 79 EUR or (-20%) $99 $79 (tax incl.)
https://www.bluecataudio.com/Product...t_PlugNScript/
"Craft your own effects and instruments"
Blue Cat's Plug'n Script is an audio and MIDI scripting plug-in that can be programmed to build custom effects or virtual instruments, without quitting your favorite DAW software.
With this plug-in, you can write your own plug-in with very little knowledge about programming. If you do not care about programming, Blue Cat's Plug'n Script can also be used as a regular multi effects processor with existing scripts or to get someone else write this very particular utility you have been searching for years and cannot find anywhere.
If you are an experienced programmer, you will find in Plug'n Script a powerful development environment for audio plug-ins: prototype algorithms quickly, generate a state of the art graphical user interface (GUI) without a single line of code, and export a VST plug-in, right from within your favorite DAW! Creating a plug-in has never been so fast!
This plug-in has been in our lab for several years and has been used to prototype lots of our existing plug-ins. It supports both scripts distributed as source code and pre-compiled binary scripts.
For source scripts, it uses the high performance AngelScript scripting engine, originally developed for video games, with a JIT compiler that helps compiling scripts into machine code for optimal performance. Starting with version 2, the plug-in also supports native (compiled) code and can load binary scripts built from C or C++ (or any language that can export C functions, such as Delphi, Fortran, .Net...), using the same interface as the angelscript version.
The syntax of the AngelScript language is close to Java, C#, C++ or JavaScript, making it very easy to learn. It is also convenient to reuse your scripts into native code, or integrate code snippets found on the web into your script. Also, switching between angelscript and binary versions of the same script is very easy, requiring very few changes.
The plug-in includes dozens of audio and MIDI processing scripts as well as several virtual instruments and utilities to enhance your workflow. They can be used as is, or as examples to get started to write your own scripts. User scripts can be shared in the scripts repository, which also includes the factory scripts and native projects for reference.
To build complex effects chains using multiple scripts, you might be interested in Blue Cat's PatchWork, which can host multiple instances of this plug-in in series or parallel. While writing scripts, you might also want to use our analysis tools to check their effect on the signal.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 10-17-2017, 07:25 PM
amagras amagras is offline
Default Re: Blue Cat's Plug'n Script 3.0 - export your creations as independent VST plug-ins
Interesting, looking forward to see some demo videos. Thx
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-17-2017, 07:27 PM
unkJE's Avatar
https://youtu.be/nQDSJc0CCAo?list=PL...Hl1wSQC6KFnZB4
Old 10-17-2017, 07:32 PM
unkJE's Avatar
Main Features:
Audio and MIDI scripting plug-in.
Build your own Audio and MIDI effects or virtual instruments.
Export your effect or instrument as an independent VST plug-in.
Simple scripting syntax, using either the AngelScript language (similar to C++, Java or javascript) or C/C++ for native code.
Native binary scripts support (compiled C, C++ or Delphi, Fortran...).
Fully customizable user interface that adapts to scripts automatically. Build your own using Blue Cat's KUIML language.
Up to 48 input parameters and 32 outputs, with full MIDI and automation control.
Use your favorite Integrated Development Environment (IDE) for editing.
Integrated JIT (Just In Time) compiler for optimal performance (scripts are not interpreted but compiled).
Includes 56 scripts with source code and 136 presets for sound synthesis, MIDI FX, audio FX (comp, gate, tremolo echo, filters, looper...), waveform generation, file playback/recording and more.
Side chain input and auxiliary outputs support.
Surround support (up to 8 audio channels).
Download free scripts from our audio & MIDI scripts repository.
Blue Cat Audio Standards:
Available as: Mac-AAX, Mac-AU, Mac-RTAS, Mac-VST, Mac-VST3, Win-AAX, Win-DX, Win-RTAS, Win-VST, Win-VST3, Win x64-AAX, Win x64-DX, Win x64-VST, Win x64-VST3.
Native DSP code for optimal performance.
Full MIDI control and automation support with silent, zipper-free parameters update, advanced response control and MIDI Learn.
No CPU load on idle: when the plug-in is fed with silence, the processing smoothly shuts down, to optimize the CPU usage of your Digital Audio Workstation.
Customizable user interface with transparency management and zoom.
Automation and MIDI output: record output parameters as automation curves or send MIDI CC messages to other plug-ins for powerful side chain effects.
Smooth Bypass: activate/deactivate the plug-in with absolutely no noise. Undo/Redo.
Full featured integrated presets manager.
Copy/paste the state of the plug-in between instances using the system clipboard.
Any sample rate supported.
System Requirements
Windows
An SSE2-enabled processor (Pentium 4 or newer).
Microsoft Windows Vista, Windows 7, 8 or 10.
Any DirectX / VST / RTAS / AAX compatible host software (32 or 64 bit).
Mac OS X
An Intel processor.
Mac OS Sierra (10.12), Mac OS X El Capitan (10.11), Mac OS X Yosemite (10.10), Mavericks (10.9), Mountain Lion (10.8), Lion (10.7) .
Any VST / Audio Unit (32/64-bit) / RTAS / AAX compatible application.
Old 10-19-2017, 07:08 AM
bluecataudio's Avatar
bluecataudio bluecataudio is offline
Blue Cat Audio
Thank you for mentioning our plug-in.
We have just issued a maintenance update for Plug'n Script to fix a problem with exported VSTs for Mac.
So Please download the latest version if you want to create independent VSTs for Mac. It is available from the same location as the original download (link received by email upon purchase - you may have to refresh the web page).
HTML code is On
Installation Script for Additional Value Content Plug-ins included with Pro Tools Marco Bernardo Pro Tools 12 23 01-29-2017 04:15 PM
Installation Script for Additional Value Content Plug-ins included with Pro Tools HD Marco Bernardo Pro Tools HDX & HD Native Systems (Mac) 8 01-28-2017 03:12 PM
Blue Cat's Plug'n Script V2.0 and New Bundle Released bluecataudio AAX Plug-ins 0 11-30-2015 05:44 AM
Blue Cat's Plug'Script 1.1 released: Audio and MIDI scripting inside Pro Tools bluecataudio AAX Plug-ins 0 10-16-2014 03:54 AM
The following installation step failed: run preflight script for plug-in updates. dojob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-06-2011 12:05 PM
