19.7 S3 Channel 1 bug
Just installed the update and now the fader, solo, mute and select knobs the first channel on my S3 is broken.
Instead of controlling the channel assigned to the first fader, it now controls any other selected channel (fade, solo , mute, select and vca spill) Its like S3 fader 1 becomes the "attentioned track". If I turn off my Pro Tools Dock it all behaves normally again. So the issue is only when the dock is connected. When I downgrade to 19.5.1 all is good, except my iPad app is the newest version and can't communicate with EuCon.. Is there a way to downgrade the iPad app as well? Hope there will be a quick fix soon... Best Regards Frede Panduro (DK)
Mac Mini 2018 - 3,2GHz I7 6-core, 32gb RAM,512gb SSD OS X 10.14.4 Pro Tools Ultimate 2019.6 EuControl 2019.7 Apollo 8 UAD Satellite Quad + Eight Core Avid S3 + Dock Last edited by fredepanduro; 08-03-2019 at 05:15 AM. |
Re: 19.7 S3 Channel 1 bug
I am having the same issue. Ch 1 fader on the S3 is basically an attentioned track even though it's assigned to auto assigned in eucontrol settings. I am also using the S3 with a dock connected.
Ron Cook Split The Difference Audio splitthedifferenceaudio.com |
Power cycle the S3 and see if the issue goes away (for good)
Same thing here. It's a pretty serious hinderance to my workflow.
I guess I'll downgrade to 19.5 until it's fixed and live without the iPad. If anyone figures out a workaround, it'd be greatly appreciated! |
Same thing here. It's a pretty big hinderance to my workflow.
I guess I'll downgrade to 19.5 and see if that solves it, although I'm guessing I'll lose the iPad. I hope this resolves itself soon. |
Same issue here.
I'm having the same issue with Ch1 fader, plus when I try to write automation for my aux while on flip mode it writes volume automation instead.
I just downgraded back to EuControl 19.5.1, is there a way to downgrade the iPad app?
Hi All, I have confirmed that I see this issue too. Can you pls try this work around?
In your 'My Surfaces' list, drag your Dock on top or in front of your S3. Functionality should return to normal. Should appear as below: PT | Dock S3 Last edited by BrianGasacao; 08-04-2019 at 11:45 PM. Reason: To give clearer instruction. |
Switching the order in your 'My Surfaces' list should fix this issue too.
Left channel click track bleeding into right channel | lokimojo | macOS | 5 | 08-29-2014 11:44 PM |
32 Channel Input / 16 Channel Output Device(s)? | tcstx | Pro Tools 9 | 33 | 02-07-2011 03:04 PM |
Strange CoreAudio issue - right channel information getting into left channel | -JK- | Pro Tools 9 | 5 | 01-10-2011 08:42 AM |
Multi-channel plugin default 'channel view'? | Floydio | Tips & Tricks | 1 | 11-26-2010 10:47 AM |
Selecting a Channel on Icon does not select channel in ProTools | teacherman | ICON & C|24 | 2 | 06-07-2010 11:59 AM |
