#21
Re: C|24 vs Others
Tom
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
#22
Re: C|24 Pros and Cons?
not thinking of it as a mixer.. but rather the control surface... but also functionality. Thats why i said with the presonus i am going to use euphonix.
#23
1) you said you want to go with HD Native and Auroras, 32 Channels max. This can be done with the standard PT9 / CPTK (which would get you the HD software features), no need for the HD Native. You'd need any good multichannel digital interface (RME HDSPe RayDat or AES or MADI) and matching converter box(es). 2) If I compare the C24 to the Tascam, Presonus regarding the DAW controller capabilities, it really isn't a fair comparison. The Tascam mixer has just a very simple HUI control layer and the Presonus StudioLive mixers don't have a DAW control capability at all (AFAIK). 3) The Artist Series controllers aren't bad, but they are small. While it might be completely sufficient for many people, I personally didn't like it ergonomically at all. If you need a very fast and efficient mixing workflow (with a client breathing on your neck), the C24 beats the Artist Series at any time. Heavy editing, however, is a domain of the MC Control, it would be faster on that, you still need to use quite a lot of keyboard when editing with C24. The build quality is a completely different level, but so is the price. 4) Despite the C24 is not a mixer, it has a lot of analog circuitry. It has 16 preamps (borrowed from the 003) and 8 stereo line input submixer, which can be useful for monitoring other studio sources (like the CD player, tape deck, etc.), or summing i.e. the effect returns. And there is also a VERY well equipped digitally-controlled 5.1 analog monitor section. Every function (Mono, Dim, Alt Speaker) has its own level trim and so has each individual speaker output. Two 5.1 inputs, two stereo inputs, can be switched or summed together at will. Built-in talkback mic with an option to use an external TB mic instead. Auto-talkback - when the PT transport is stopped, the talkback is automatically switched on. So to sum it up, it's a very good monitor section and comparable standalone units are very expensive. Hope it helps. :) Tom
#24
This really helps... So you think that PT9 would be sufficient for me, but you suggest going with the C24 as my control surface and then using high end converters with there own pci card so th e money saved there could be spent on the C24. Great advice. As I am talking through further, is the C24 able to work with Logic 9 as a control surface?
I do most of my composition in Logic 9 and then switch over to Pro Tools for the producing side of things. |
#25
Tom
#26
I am going to bite the bullet and go with the HD as the main interest for me with PT is HEAT plug in. But I am now going to use an analog board for mic pres and routing and premium converter - looking at Apogee vs Aurora and use the MC Mix and MC Control. Thanks Pro Tools would be my base but Logic would be for preproduction and composition.
#27
Yep, that should work fine.
001 vrs mix 24, pros n cons | westgate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-10-2003 03:07 PM |
PT LE for Win. XP v. Mac Pros and Cons? | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-23-2003 11:00 AM |
pros and cons | SPstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 01-11-2002 09:52 AM |
Pros and Cons | SPstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-11-2002 06:05 AM |
USD vs SSD+VSD, pros cons | synthetic | Tips & Tricks | 2 | 08-22-2000 11:24 AM |
