Can't sync sample rate with TF3
Hi All,
There is a problem of the sample rate synchronize between Pro Tools First & The Yamaha TF3, wondering is there anyone have this problem too. Firstly I've set the Pro Tools Aggregate I/O as 48k from TF3 clock source (as the photo). ???? 2016-04-07 ??1.36.01.jpg And I've opened the Pro Tools First software with Keyboard "N" and goes to Playback Engine Dialog, as the as setting as the photo below, ???? 2016-04-07 ??1.46.31.jpg But the problems appear when i was try to create any new projects, the sample rate will automatic turn to 44.1k in Audio Setup & Playback Engine Dialog as the photo below, ???? 2016-04-07 ??1.52.55.jpg Then the TF3 keep showing the msg "USB Sample Rate Mismatch on USB. Console:48000Hz" that i can't do operate or recording. Is anyone have ideas how to fix that issue ? |
Re: Can't sync sample rate with TF3
Please, Is that anyone have ideas of the issue...?
Thanks so much ! |
did you ever get this sorted out?
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
HD IO and ADAT sync at 192 sample rate? | RTASW | Pro Tools HDX & HD Native Systems (Mac) | 1 | 08-03-2013 07:34 AM |
Problem Opening Sessions in Pro Tools 9: Sample Rate Sync Issue. | anthonymunoz | macOS | 0 | 10-23-2011 08:49 PM |
Changing SYNC IO Sample Rate Without Protools Open | joshlynch | Pro Tools TDM Systems (Mac) | 1 | 03-20-2006 03:46 PM |
sample rate external sync error, please help | wooofff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-10-2005 03:35 AM |
Correct ADAT sync mode and sample rate? | Stenjy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-23-1999 11:48 AM |
