Old 05-04-2008, 01:39 PM
Defekt Defekt is offline
Default Spinning Wheel when playin audio
Hello.
I'm normally a Pro Tools LE user, but a friend has had me set up their pro tools HD rig with a mac pro. Everything seems to be working fine except that when doing otherwise simple tasks such as playing back a song with just a handful of tracks. I get the spiinning wheel for about 5 seconds before it plays. once it finally does, I can move it around without any problems for while. But if I stop and do some editing then come back and hit play, i'll get it again.
Now he's running HD 7.4 on a Mac Pro Quad-core with a Magma Expansion chassis and an HD192. He has 1 core card and 2 process cards in the chassis and 3 GBS of ram. I've tried various buffer settings and still can't seem to get it to stop. I'm new to the HD world, so perhaps there is a setting or preference I'm not familiar with that could be causing this?
Now my LE system at home is on the same computer with an 002 rack and it runs flawlessly. I've hooked his rig up maticulously: what could be the issue?
Thanks for any suggestions.
MacBook Pro 2018
Pro Tools Ultimate 2023.9
EuControl 2023.11
Avid Control App 2023.11
HD Native Thunderbolt
HD I/O + Omni
Avid S1 x 2
Old 05-04-2008, 04:11 PM
Andre Knecht Andre Knecht is offline
Default Re: Spinning Wheel when playin audio
A few things come to mind…
Did you disable the CPUs being allowed to nap?
Are drives allowed to spin down?
Is Spotlight Indexing disabled?
Are you mixing FW 400 and 800?
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 05-06-2008, 07:06 PM
Some good thoughts. I'm pretty sure I covered all that. But next time I'm there I'll double check. Your referring to the system preference settings for put hard drive to sleep and the energy saver setting for the CPU Right? Any other ideas?
MacBook Pro 2018
EuControl 2023.11
HD I/O + Omni
Avid S1 x 2
Old 05-06-2008, 07:45 PM
You may want to get a Universal Binary copy of TechTool Pro or DiskWarrior and scan for directory errors. These types of errors can cause the SWOD, as can a failing hard drive.
Spinning wheel of death again Stickman7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-22-2010 04:05 PM
Spinning wheel of death Stickman7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-25-2009 06:42 PM
Spinning wheel before recording ? tactics 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-08-2009 04:37 AM
Help? Spinning wheel for 10 seconds when trying to record... popps Pro Tools TDM Systems (Mac) 7 01-23-2008 11:27 AM
Spinning wheel of death!!! alw4416 Pro Tools TDM Systems (Mac) 3 12-09-2007 10:56 AM
