copy and paste surround panner?
is there a way to copy/paste surround panner settings - like shift-cmd-c/v in plug-ins?
Re: copy and paste surround panner?
Edit menu>Copy Special>Pan Automations> then fill selection where you need it by Opt+Command +V.
Much easier if you are on Icon console: Func 1 - CopySp PanAut > Func 1 - PasteSp - Pan Aut
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
or-
If no automation is involved Duplicate track w/o clips Move the other audio to that track. If there is automation but you wish the new panner settings the disable automation follows edit (icon next to mirror midi edit) prior to moving clips.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
thanks a lot.
copy-special is the way I do it most of the time. But as I often work in preview-mode and sounds are built up with lots of tracks, it would be nice to have such a function for all the knobs and faders in the output window. doesn't seem to exist |
If the panning automation is to be copied to a different selection, but on the same track, this works too :
Automation Window : deselect everything than Pan in the selection with the desired pan automation to be copied : Alt+Capture new selection , Punch Capture , write manually from start to end of selection (more mouse action than special copy)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
There is a way to Copy Special Pan Information but there is no clear way to Paste surround panner info. This has frustrated me for years. I tried pasting option + Command + V . But this does not work. If anyone can share the secret other than use a console command please share. Thanks!
If you need to do the whole track, you can create a track present for recalling pan only and then apply it to other tracks.
If you need to copy pan automation, then go to Copy Special and you will find Pan Automation. Then do a regular paste on the track you want to copy to. All pan automation with copy over for surround (all categories of pan) Or paste>repeat to fill selection if you aren't selecting the same region time as what you copied. Works 100% here.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Why not simply have a surround panner presets popup, just like we have for plugin settings ?
Copy... Paste... Paste... Paste...? | accession | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-18-2022 04:18 PM |
Copy works paste doesnt paste??? | SoMedia | Pro Tools M-Powered (Win) | 12 | 01-04-2011 01:19 PM |
can you copy your surround panner to another? | JohnnyB | Post - Surround - Video | 1 | 04-15-2010 08:16 PM |
Shuffle doesn't shift volumes - copy & paste doesn't copy automation | marcnyc | Pro Tools TDM Systems (Mac) | 2 | 03-12-2010 12:46 AM |
surround panning info copy and paste? | hairysound | Post - Surround - Video | 1 | 03-28-2003 04:37 AM |
