Best way to use VI Drums eg SSD4, Superior Drummer
I started off years ago using Superior Drummer recording midi then I would route the drums to seperate tracks record it then eq, comp etc to my taste. Im now using Steven Slate Drums 4 because I just love the drum sounds I'm just courious how everyone is doing this.
I started thinking about changing my work because I've encounted a pain in the butt when it comes to mixing With my previouse method record each drum to its own track then edit, sometimes I've found a drum didn't sound right, Hi-Hat is too high in the overheads which would then result in going back into SSD4 messing sound to get it right then rerecording the problem track again. But I've come to the conclusion I might just route all the seperate drums to their own Aux's instead of audio tracks so the audio comes from SSD4 through the Aux's and I can edit, eq comp from there. (hope I'm making sense) This way I could hear the changes as I do them in SSD4 without committing it to a track. I'm thinking this would speed up my work flow I'm wondering how everybody else is using these VI all suggestion would be much appreciated
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Best way to use VI Drums eg SSD4, Superior Drummer
This is fine as long as your computer can handle it. One of the main reasons for printing to audio is to take the load off. The other main reason would be for archiving purposes (in case you don't have that program anymore, years from now).
Archiving!!! Never thought of that problem later down the line. That's one to think about
Raoul Crane
With SD2, I often felt that there was always too much snare in the overheads. My solution was, after printing audio tracks for all drums(and overheads), I would go back to the kit, change the snare selection to NONE and record the overhead track again(this time with no snare bleed at all). Having total control can make a big difference come mixdown. You may be thinking how unnatural that is, and you would be right. BUT, would all of us engineers opt for total isolation if you actually could do it with a live kit?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 3-6-18) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
I do most of the drum mix inside SD 2 nowadays. I like the included plugins. I usually split out the snare to a separate aux in PT so I can send it to a reverb, but not much else. Printing VI's for archiving/remixing purposes is a big advantage.
And that dude is the man!!!!!!!
Raoul Crane
Boy, I don't know Albee. I can see your point...on the other hand, that isn't how we hear drums. Not sure if total isolation, even if possible, would sound as good as we get now! Just my $0.02.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Between your 2 cents and my 2 cents.....hey, we got 4 cents...woohoo!
Rail
New Toontrack video about using E-Drums with Superior Drummer | nst7 | The Drum Room | 0 | 11-20-2013 07:29 AM |
Superior drummer or Steven slate drums | Raoul23 | The Drum Room | 20 | 01-27-2012 03:06 AM |
Midi from drums through command 8 then superior drummer | Raoul23 | The Drum Room | 3 | 09-29-2011 05:15 PM |
mapping superior drummer to drums | spidey01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-02-2008 09:10 AM |
Big [bleep] Drums, or Superior Drummer? | Peterjk | Virtual Instruments | 3 | 03-03-2006 11:04 PM |
