Old 01-05-2021, 05:03 AM
spoteye spoteye is offline
Default Re: There are more active audio tracks than the allowed maximum
Originally Posted by Top Jimmy View Post
No, you have 41 regions (aka clips) on one track in your session.
Have you tried trashing prefs?
https://www.sweetwater.com/sweetcare...s-preferences/
Googling AAE error 6009 brings up the possibility that sharing your audio interface with Windows may be causing a conflict. Put the Windows default audio device back to onboard input and output so that only Pro Tools is accessing the M-Audio Air 192|14
Hi
I did this:
Pro Tools 11, 12, and 2018
Close Pro Tools.
Hold the Windows key on your keyboard and press R.
When the Run window appears, type %appdata% and press OK.
Open the Avid folder, and delete the Pro Tools folder.
Restart your computer and launch Pro Tools.
still have same error:
There are more active audio tracks than the allowed maximum.
As a result, one or more audio tracks well not play.
after saving 4 audios
now computer sound working on sound card Realtek Audio deferent than the Pro Tools hardware M-Audio 192/14
Please help and tell me what to do to fix this issue
Thanks
Old 01-11-2021, 11:39 AM
Top Jimmy's Avatar
I didn’t see your reply until now.
I would try a complete uninstall and reinstall of both Pro Tools and the M-Audio driver.
If that doesn’t work, try installing ASIO4all and try using the onboard audio with Pro Tools and see what that does.
James Cadwallader
Old 01-18-2021, 04:40 AM
Hi
still same error no changed
when I used before Pro Tools 11 not face these error and have this problem
now with Pro Tools 12 I have many error and can not working like that wasting very long time for saving files for each track saving I have close the Pro Tools and restarted again for saving another track
Please still I need help to solve this problem
Thanks
Old 01-18-2021, 04:53 AM
Same these error come after saving each track
1-There are more active audio tracks then the allowed maximum. As a result, one or more audio tracks will not play
2-Could not complete the Exit command because Access violation occurred, unable to read location: 0x0000000000000000
Pro Tools verion 2020.12
Thanks
Old 01-18-2021, 11:11 AM
Top Jimmy's Avatar
Originally Posted by spoteye View Post
Hi
Thanks
Share just the Pro Tools session file via Dropbox or your favorite file sharing service and I’ll take a look.
James Cadwallader
Old 01-19-2021, 04:58 AM
Hi
Computer Information:
Windows 10 Pro
System:
Processor: Intel(R) Core(TM) i9-9980XE CPU @ 3.00GHz 3.00 GHz
Installed memory (RAM): 144 GB ( 144 GB usable )
System type: 64-bit Operating System, x64-based processor
pen and touch: No Pen or touch Input is available for this display
Drivers:
M.2 2TB (C:) 1.66 TB free of 1.81 TB
Disk (D:) 4.11 TB free of 7.27 TB
Disk (E:) 6.39 TB free of 7.27 TB
Disk (G:) 61.0 MB free of 99.9 MB
Disk (H:) 826 GB free of 930 GB
Pro Tools Version 2020.12.0
errors:
1-There are more active audio tracks than the allowed maximum.
2- Could not complete the Exit command because Access violation occurre,
unable to read location: 0x0000000000000030
Please help me to solve this problem and use the software without any errors
Thanks
There's some weird drive allocations especially with those G and H drives. And what speed are those 8 TB spinners (D & E drives)?
Old 01-19-2021, 05:15 AM
Disk allocation has nothing to do with track counts. However the original poster has not told which sampling rate the session is running. PT Standard maxes out at 32 tracks if the session is 192kHz. No reason to edit/mix in that resolution, but for some bigger number is better, but in this case it is not.
Old 01-25-2021, 02:22 AM
Old 01-25-2021, 03:04 AM
Hi
Still same message come after saving two files
more active audio tracks than the allowed maximum... x0epikhigh0x macOS 2 12-10-2019 03:16 PM
Maximum Allowed Activations MyerzMedia Eleven Rack 19 02-17-2014 07:59 AM
Maximum Tracks Allowed/Pro Tools Mix System unseen33 Pro Tools TDM Systems (Win) 1 02-15-2007 08:14 PM
What's the maximum no of plugs allowed? K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-05-2004 07:50 PM
