Old 12-21-2020, 08:29 AM
[email protected] sleshnyc@gmail.com is offline
Default Can I create an 8 fader custom group on an 8 fader d command?
It seems the limitation of custom groups is due to me only having an 8 fader d command. So I have to limit my custom fader groups to 4 faders so the other four I can use to select which tracks I want in the group. Is there a workaround to this? It would be great if the tracks showed up in the matrix and I could choose that way. Any help appreciated.
Old 12-21-2020, 08:50 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Can I create an 8 fader custom group on an 8 fader d command?
You can just use normal pro tools groups. hold the groups button till it flashes then press bank/cycle button and the pro tools groups can be selected. does this help?
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-21-2020, 08:56 AM
You could also create 8 VCA tracks(assigning as needed) and place them at the right of all your other tracks, and then bank to them on the surface
Renaming Custom Fader Banks (D-Command) legasafe ICON & C|24 1 11-24-2009 02:06 AM
D-Command Custom Fader question macaholic ICON & C|24 7 03-25-2009 05:27 AM
Custom Fader Group Question GlennR01 ICON & C|24 9 01-14-2008 05:29 PM
Custom Groups, Can it be don on an 8 Fader D-Command? laki ICON & C|24 2 07-26-2007 04:53 AM
Custom Fader Mode on D-Command (TURN OFF) EvanScottSmith ICON & C|24 1 01-31-2007 04:07 PM
