Old 12-17-2014, 11:14 AM
Kiergtr Kiergtr is offline
Default Mobilepre and Garage Band
I am new to the forum. I have an old M Audio Mobilepre and a newer Macbook pro running 10.9.5. My Mobilepre is not detected by my Macbook. Do I need a driver update? Is there even one available?
Thanks,
Kiergtr
Old 12-17-2014, 11:28 AM
Stig Eliassen's Avatar
Default Re: Mobilepre and Garage Band
MobilePre drivers
Thanks,
Kiergtr
http://avid.force.com/pkb/articles/e...ilePre-Drivers
Make sure you have to correct (latest in this case) driver installed. If that is not it debug the USB cable and remove all other USB periperals you can and restart the computer. Make sure you have have disabled power management/sleep and never manually sleep/suspend/shut the lid of the MacPro with the interface attached (or it will likely disappear from OS X... I assume but don't know for sure that common Avid interface driver issue is an issue with these drivers as well)... if so you need to reboot the Mac. If you want more help here you need to provide much more detailed system info, start at the "Help us Help You - READ THIS Before Posting! above.
Old 12-17-2014, 11:34 AM
I will check the "Help us Help You" but I think that I might have the first generation MobilePre. I have read that there is not an update available to be compatible with 10.9.5 Is that right?
Old 12-17-2014, 12:18 PM
All you need to know/all folks here do know is on the Avid driver pages.
Configuring Garage Band drummer9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-20-2009 06:30 AM
Garage band randa112 Pro Tools M-Powered (Mac) 2 11-08-2008 07:50 PM
Garage Band 1 Help. tempest1226 Virtual Instruments 5 02-16-2007 05:51 PM
Digi 001 +Garage Band squeezebob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-02-2004 03:57 PM
Garage Band Arrives Diesel10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 01-17-2004 12:47 PM
