Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
  #21
Old 10-15-2012, 09:04 AM
scon777 scon777 is offline
Default Re: MBox3 Pro dsp effects
Yea...just swapped it out
  #22
Old 10-17-2012, 09:37 PM
dtitle dtitle is offline
I'm having the same problem. I'm using windows and pt 9. I bought this mbox pro 3 so I could use the onboard effects when I'm using the low latency option (which disables the plug ins on the channel you're recording on) to hear some reverb when I'm singing. I've got the mbox mixer up on the screen, all the sends and returns are up full and can hear no effects in the headphones. How can I get the dsp effects into the signal flow? I haven't found one step by step explanation on line. I'm looking for something which i.e. turns on the sends (a bus in the Mbox mixer) but find nothing. Anyone, thanks for your help.
  #23
Old 10-19-2012, 05:44 AM
jackattack713 jackattack713 is offline
I am having same problem, i've read threads above, double checked all same settings, downloaded latest drivers, etc. Slight bit of hassle to send unit back in and swap, so if anyone finds another solution (or avid person is looking at this thread) any suggestion would help.
btw, I'm running it on a late 2011 Macbook Pro 10.7.4
  #24
Old 10-19-2012, 08:06 AM
fsilano fsilano is offline
Default
I have a ticket open and am waiting for some guidance from Avid but so far not much help. I also have the option to return/exchange so I might do that if I don't hear back soon.
Update: I heard back from Avid Support and they indicated that they are investigating and that it may be a driver/firmware issue...
Avid/Digidesign Technical Support:
"...It may be firmware related in which case swapping out the hardware is probably not the best solution. I may be that it needs to be resolved with a firmware/driver update. If this is the case you could get another unit but as soon as you update the driver required to work with Mac OS 10.8.x there is a strong possibility you will have the same issue again. If replacing the Mbox Pro makes sense this is something we can do with you directly. It may be that you will need to wait for an update from us that changes the firmware in order to completely resolve this issue."
I also sent the the URL to this thread for reference.
-Frank
Frank Silano
FrankenCat Productions
Landmine Recording
Tampa Bay, Florida
http://www.frankencat.com
PT 2018.12 (Win)
PT 10.3.10 (Win)
Mbox Pro Gen 3 Firmware 1.0.4
Focusrite 18i8 Gen 2 (mobile rig)
Windows 10 Enterprise (main PT OS)
Mac Mojave 10.14.4 (no PT at the moment)
  #25
Old 10-25-2012, 01:08 PM
tdstudio tdstudio is offline
Default tuner not working on mbox pro
I have the latest drivers for mbox pro & I am using pro tools 10.3.2
I cannot get the tuner to work at all... everything else seems perfect...
  #26
Old 10-25-2012, 04:34 PM
serio serio is offline
Default Re: tuner not working on mbox pro
Fellow DUC member jryser has had that issue as well. It's one out a few problems with the current mbox pro software. Hoping for more fixes...
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
  #27
Old 10-25-2012, 06:20 PM
jryser's Avatar
jryser jryser is offline
Default
Indeed this is true for me still. I had an excellent support person who worked with me over several days to try to fix the problem. I wondered if my firmware upload glitched or something. So I still have that lost tuner as the only issue with my Mbox!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #28
Old 10-25-2012, 06:53 PM
Default
Do your dsp effects work? What version of firmware and software are you on?
Sent from my SGH-T989 using Tapatalk 2
Frank Silano
Landmine Recording
Tampa Bay, Florida
PT 2018.12 (Win)
PT 10.3.10 (Win)
  #29
Old 10-25-2012, 07:37 PM
jryser's Avatar
Default
The absolute latest drivers and firmware. It's a fairly odd issue that does not appear to happen often.
  #30
Old 10-25-2012, 08:28 PM
Default
Are the dsp effects working? A few of us are having this issue and avid is supposedly looking into it.
Frank Silano
Landmine Recording
Tampa Bay, Florida
PT 2018.12 (Win)
PT 10.3.10 (Win)
tuner not working on mbox pro tdstudio macOS 5 10-25-2012 08:28 PM
Tuner on MBox Nick@KNR Windows 1 09-29-2012 07:37 PM
MBox 3 pro guitar tuner - can't access it Delianguy General Discussion 0 04-07-2012 12:51 AM
BF Essential Tuner issue jgehring 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-09-2007 11:44 AM
