#41
Re: S3 vs Two S1's
Thanks, are there any plans to add a preference to bank by the number of surfaces available? For example, to be able to bank by 16 if you have two S1's and so forth.
#42
Re: S3 vs Two S1's
Not currently but S6 does that so maybe (after some of the other stuff we have planned)
#43
Re: S3 vs Two S1's
I travel a fair bit and I personally feel that a couple S1 is probably more what I'm looking for. I can have 2 of them for my mixing rig in my studio and I need to travel I can just chuck one in my bag easy. I don't really need the pres on the S3... I have quite a few mixers friends who own an S3 and are thinking about getting a couple S1 instead for the same reason... the price difference is not that much when adding the tablets, but it is the modularity that makes it great for what I need it to do.
#44
Re: S3 vs Two S1's
Is there anyway I could help push for that feature? I just got my two S1s and that is the only fault I've experienced with these amazing units :) Thanks! |
#45
Re: S3 vs Two S1's
I too am considering this move from S3 to two S1's. Mainly for a bit of space-savings and the S6 style metering.
However, I use "solo clear" constantly on my S3, is there a similar feature on the S1? I guess I also have to consider the Dock too, would be good to have that sweet master fader. Justin |
#47
Re: S3 vs Two S1's
Thanks Jeff...without any modifier keys or anything?
#48
Re: S3 vs Two S1's
PT 2024.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Studio M2 Max on Sonoma, 64GB RAM, 4 TB & 8 TB external SSD NVMe drives, Neve 1073OPX(2), Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VI’s and plug ins to mention. |
#49
Re: S3 vs Two S1's
Yep! If you create a EUCON command for your chosen button in EuControl, "Clear Solo" is tucked away under "Global". You could program it so it clears both Solos and Mutes with a single button press if you really wanted to...
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#50
Re: S3 vs Two S1's
I'm not sure that anybody has mentioned the S3-only feature "Multi-Master Mode". This has been a KILLER workflow for me!
I have another setup that I have been used to which includes: 4 Artist Mix/1 Artist Control/1 Avid Control/1 JLCooper Surround Panner for ES I thought I needed and wanted more faders. The more the merrier, right? WRONG! With S3+Dock and Multi-Master Mode, I don't need ANYTHING else and it's all comfortably right in front of me. I wouldn't swap for multiple S1 over the S3. I'm very happy with this!
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
