Old 01-02-2010, 02:04 AM
Mix Master Factories Mix Master Factories is offline
Default New Playlist shortcut?
Is there a shortcut for creating new playlists?
The way I do it now is that after each take is recorded I press the little arrow beside the track name and create a new playlist. But it's a little clumsy as I often forget to create a new one. The takes get stacked on top of eachother making it hard for me to retrieve them. Especially when working with groups.
Alternatively, is there a way to automatically create a new playlist after each take (like in loop mode, but without loop actually enabled)?
Old 01-02-2010, 10:52 AM
Default Re: New Playlist shortcut?
Nope probably second on the list after ADC of most requested features.
filosofem
Old 01-02-2010, 01:35 PM
test tube AUDIO test tube AUDIO is offline
What you can do is just drag each take into the empty grey lane ( when the track is viewing "playlist" instead of "waveform" ) that will automatically create a new playlist. Also, it helps to hold control so that your region doesn't accidentally shift right or left. Hope this helps.
Old 01-02-2010, 03:08 PM
filosofem
So you mean there's a new playlist shortcut in HD?
It can't be that hard to add a shortcut compared to ADC.
Old 01-02-2010, 03:44 PM
This is the Pro Tools LE Native Systems forum.
filosofem
Old 01-03-2010, 03:32 AM
filosofem
That was a helpful post.
New playlist shortcut? jdutaillis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-20-2009 10:22 PM
New Playlist Shortcut zwiersd Pro Tools TDM Systems (Mac) 1 04-23-2009 04:51 AM
Shortcut for NEW PLAYLIST ? John Edwards UK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-22-2008 06:25 AM
Shortcut for "New playlist" FrauMitBart Pro Tools TDM Systems (Mac) 1 04-01-2005 12:57 AM
select playlist shortcut jdhiler Tips & Tricks 7 03-10-2005 08:52 AM
