Old 05-01-2003, 11:03 AM
james twomey james twomey is offline
Default midi trigger
How do I create a midi trigger from (let's say) a snare drum so I can replace it with another sound?
Old 05-01-2003, 01:02 PM
Kev Kev is offline
Default Re: midi trigger
In an edit situation just place midi note at every snare. Time consuming.
A midi drum module like D4 DM5 .. Vdrums etc will do the trick. D4 second hand is worth a look.
Seems there should be a plug for this but midi related plugs just aren't in PT yet.
Old 05-09-2003, 07:40 AM
florian sommer florian sommer is offline
why using midi @ all? try using soundreplacer plug. get the audio off your midid device, and use it with soundreplacer. fastest way i know for replacing drum sounds.... works great.
rock on
florian
Old 05-09-2003, 03:11 PM
Kev Kev is offline
because midi opens the door to samplers and other sound devices.
midi is also a fantastic music production tool that has been with us since the early 80's.
midi files are small and easy to send via email to other musicians and you can swap arrangement ideas and new songs using files the size of text files. (you can't change tempo like you can in the midi world)
unless you start using midi on something you will never know.
I often have a midi file underneath a drum track even if I have used Beat Detective.
Can't trigger via midi rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-17-2009 02:23 PM
Using audio to trigger midi soundonsound Pro Tools TDM Systems (Mac) 3 04-24-2008 10:07 AM
Alesis D-4 trigger to Midi studioslave77 MIDI 1 02-15-2008 06:31 AM
MIDI Trigger... JediMasterHarker MIDI 5 10-07-2004 11:38 PM
Old DX7IIFD Midi trigger set up ibsmith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-30-2001 03:47 PM
