Old 03-25-2024, 07:03 AM
foret_sombre foret_sombre is offline
Default Solo moves track on top
How can you disable the track going on top of the edit window when soloing ? I can't find anything in the doc under "Solo".
Pro Tools Ultimate 2024.3, Monterey 12.7.1, M40 S6
Old 03-25-2024, 08:33 AM
Default Re: Solo moves track on top
Are you running Eucon? I think there is a setting in Eucon for this.
Old 03-25-2024, 10:07 AM
My second guess was that it is Eucon-related, but nothing was done on the S6 at the same time. I'm going to check, thanks!
Old 03-25-2024, 10:11 AM
audiogamble audiogamble is offline
Sounds like you should have a play around with eucontrol for sure
Old 03-25-2024, 10:43 AM
BScout BScout is offline
Since you are on an S6, you don't have "Eucontrol."
Your issue is probably the Pro Tools Preferences settings under Preferences > Mixing > Controllers box.
Probably the "Edit Window Follows"
You've probably got turned on the touched track becomes the "select" track (can't remember the Avid terms but attentioned track = select track) in the S6 preferences and then Pro Tools is following to scroll to it based on the Pro Tools preferences. You need to turn one of those off to prevent what you are seeing.
Old 03-25-2024, 10:53 AM
devinemke's Avatar
devinemke devinemke is offline
juts to follow up on what @BScout was saying, take a look at this section of your Pro Tools Preferences (under the Mixing tab):
File Type: png Screenshot 2024-03-25 at 1.40.48 PM.png (60.0 KB, 0 views)
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 03-26-2024, 02:59 AM
It was indeed the mixing preferences, thank you!
Track moves while grab/trimming KS#arp Getting Started 3 01-29-2022 05:44 PM
Solo 1 Track When Many Solo Tracks Exist... Sparky1 Pro Tools 12 7 03-29-2017 02:43 PM
Grouping a midi track with an audio track- only Solo works.. dumbeat Pro Tools 10 2 05-02-2015 07:25 AM
Grouping a Midi track W an Audio/Aux track- only solo works... dumbeat Pro Tools 11 6 04-30-2015 02:09 PM
AUtomation moves still not following file moves Ty Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-05-2006 01:19 PM
