Old 03-21-2024, 03:57 PM
bluesatyr bluesatyr is offline
Default Pro Tools Ultimate 2024.3 Freeze on Boot Ventura 13.6.5- FIXED
Just updated to Ultimate 2024.3 in Ventura 13.6.5 and PT would freeze on Boot.
Freeze would occur while loading Elastic Audio.aax
Removed and installed all plugins by groups, then one by one - booting and quitting pro tools along the way.
Finally discovered the culprit. VoiceChangeer.aax plugin. Now all is booting and working fine.
Just a heads up.
Old 04-08-2024, 12:35 PM
Intransit Intransit is offline
Default Re: Pro Tools Ultimate 2024.3 Freeze on Boot Ventura 13.6.5- FIXED
Thanks
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 04-08-2024, 01:35 PM
tope d's Avatar
tope d tope d is offline
Just a heads up.
seems to have similar symptoms with https://duc.avid.com/showthread.php?t=427717&page=3
thanks for the info!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
HD driver 2024.3 not working properly with Ventura 13.6.3? Frans29 Pro Tools 5 03-21-2024 11:00 AM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
Assertation in ProTools Ultimate 2024.3.0 IrelandM Pro Tools 1 03-11-2024 09:27 AM
pro tools ultimate 2023.12.1 freeze and crash iljunegate Pro Tools 1 02-14-2024 10:47 AM
Fixed: Intermittent Graphic Freeze When Using Pro Tools crizdee Pro Tools TDM Systems (Mac) 4 10-03-2007 07:25 AM
