Old 03-13-2024, 04:24 AM
samplaire's Avatar
samplaire samplaire is offline
Default FYI PT 2024.3 not compatible with InstaChord 1.3.2
Just to let you know - I had a problem with launching PT 2024.3 right after its installation. After an hour of investigation I've managed to nail the problem. It looked like PT crashes during the mentioned plugin check...
The solution was to remove the plugin from the Plug-ins folder.
No problems with this plugin in PT 2023.12.1 though.
Hope this will save your valuable time
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 03-13-2024, 11:34 AM
tope d's Avatar
tope d tope d is offline
Default Re: FYI PT 2024.3 not compatible with InstaChord 1.3.2
Thanks for the info, samplaire!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
2024.3 Crashing CHRIS AIKEN Pro Tools 8 04-25-2024 09:57 AM
PT 2024.3 | Released TrentWilliams Pro Tools 211 04-11-2024 12:20 AM
PT 2024-03.0 Hangs jlthla macOS 9 03-25-2024 10:22 PM
What I would like to see in ProTools in 2024 ! stevegalante Pro Tools 125 03-25-2024 12:37 AM
Pro Tools 2024.6 unkJE Pro Tools 1 03-07-2024 08:28 PM
