Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 02-07-2024, 05:26 PM
rd2rk rd2rk is offline
Default New Session Error in PT Intro
Just installed most recent version.
Attempting to create a New Session returns this error
"Could not create a new document because The system cannot find the file specified. (2) c:\Users\blues\OneDrive\Documents\Pro Tools\First Session. "
Where "First Session" is the name I'mm assigning to the NEW session.
Doesn't matter where I try to create it.
OF COURSE it can't find the file. It hasn't been created yet!
Dashboard screenshot attached.
Old 02-08-2024, 02:13 PM
junkgear's Avatar
junkgear junkgear is online now
Default Re: New Session Error in PT First
Have you tried saving the session to a location outside of the OneDrive folder?
As a test, you can create a directory 'C:\temp' and try storing a session there. Just make sure whatever user you are logging in as has permission to write to that directory.
If that works, then create a directory that makes more sense, but not on OneDrive.
Will
System Details
Old 02-08-2024, 10:38 PM
Thanks. That occurred to me, but it doesn't matter where I try to create the session. Even a folder in the root C drive.
Old 02-09-2024, 02:18 PM
sw rec sw rec is offline
Is this really “Pro Tools FIRST,” or Pro Tools Intro? First, if memory serves, will only do cloud sessions. And it’s been discontinued.
Old 02-09-2024, 03:27 PM
Intro. Fresh DL and install after wiping my HD and registry of anything related to AVID.
Old 02-09-2024, 03:52 PM
Did you do ALL of the Windows optimizations? Set permissions?
Old 02-11-2024, 02:00 PM
I have installed at least 5 other DAWs on this machine and THOUSANDS of other applications over the years on machines starting with the original IBM PC (Commodore 64 actually) and NEVER have I had to do anything regarding permissions. I am ADMIN. If I install it, it should work!
BUT - this being AVID, I checked permissions, and everybody logged into this PC (NOT MAC) has full permissions to the directories in question.
If I'm missing something in this regard, please be specific.
Still not answered - WHY is Pro Tools Intro looking for the file that I'm trying to create and that therefore hasn't been created yet? Where's the logic in that? Should be a clue for someone who knows this SW?
Old 02-13-2024, 08:49 PM
OK, I finally got it to create a session! You have to select "Prompt for Location", click CREATE and create it in a directory somewhere other than the default location.
Next question - the whole point of this exercise was to try the Helix Native AAX Plugin. It's located in the same directory as all the Avid plugins, but doesn't appear in the plugins list for the Insert slots. I'm suspecting that this is because INTRO does not support 3rd Party Plugins?
Old 02-13-2024, 09:29 PM
Yes, it does support 3rd party plugins. Wondering, for no more than I know about Helix, is it a stereo plugin that won’t show up on a mono track, or vice-versa?
Or is it maybe an instrument that needs to have an instrument track, not an audio track?
Old 02-14-2024, 06:17 AM
tope d's Avatar
tope d tope d is offline
Default Re: New Session Error in PT Intro
Is the same happening on Mono and Stereo track?
Might be a stereo or mono only plugin. I have not tried this third party plugin yet but I’ve encountered similar issue where if doesnt appear in the inserts. Sometimes it’s in stereo onlyso you have to load it on a stereo track and vice versa
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
[Solved] Pro Tools Intro: Download Error via Avid Link mrinne Windows 1 02-10-2024 07:26 PM
"Session Setup" window is cut off in Pro Tools Intro [PT-296402] lego Pro Tools 19 03-28-2023 09:40 AM
Avid Link activation error pro tools intro alriqa Pro Tools 2 03-21-2023 11:05 AM
Error DAE cant get audio from drives fast enough -9073 error on BIG MIX SESSION dairyman3833 Pro Tools 10 4 06-26-2014 08:35 PM
