Old 07-30-2023, 08:28 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default EdiCue v4 - Create ADR Cues within Pro Tools and Nuendo
Just released #EdiCue v4.1.0. with the following new features, minor changes and bug fixes:
  • Added Netflix TTAL file (.ttal) import and export
  • Added SubRip subtitle file (.srt) import
  • Added checkbox "Assign cue numbers to inactive (muted) cues" on 'ADR Cue Numbers' tab
  • Added checkbox "Create 'All' character/department PDF files" on 'Export Settings' tab
  • Now exports an "ALL" department MIDI file when more than one department is exported
  • Can now parse embedded characters while importing ADR Cue data from delimited text files
  • Added "Safety" (Safety Only) filter to 'General Settings' tab for ADR Cue exports
  • Increased number of Filter Presets that can be stored to 15
  • All filter presets can now be assigned to a PDF Layout to create layouts with custom filter settings
  • The TBW filter preset is now created by default and cannot be changed
  • Can now set up to 7 different PTX clip colors
  • Actor name is added to PTX ADR cue track comment fields
  • The PTX Template window can now import a CSV text file to import a list of character names or character and actor names
  • While loading PDF script, now only load character names that aren't already in the window, so scripts can be appended
  • While importing character names from a PDF Script or CSV file, unique IDs are now auto generated
  • Updated name of char/dept PDF sub-folders to contain just the name set up on the 'General Settings' tab
  • Updates to Pro Tools control code to full support macOS Ventura
  • Updates to various UI controls so they are shown correctly on macOS Ventura
  • Update to PTX import code to read new audio track widths created by PT2023.6+
  • Can now open the manage production window when no productions are defined in order to import one or more productions from a different system
  • Fix while loading preferences file on start up to stop potential hang in non-English countries
  • Fix to export of Note field while exporting 'Warner Bros LA' character text files
  • Fix for ADR Summary total percentage values to work in non-English countries
  • Fix to allow load of EdiCue PDF data that contains an empty 'Line' field
  • Fix so 'Check For Update' window shows info text
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
Old 08-25-2023, 02:45 AM
mfranken's Avatar
Sounds In Sync
Default Re: EdiCue v4 - Create ADR Cues within Pro Tools and Nuendo
Just released #EdiCue v4.1.1 with the following minor updates:
  • Fix for Windows users to allow exports of PDF files. Bug introduced in v4.1.0
  • Updated PACE license software
Mark Franken, MPSE
Old 09-21-2023, 06:45 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v4.1.2 with the following minor updates:
  • Changes required for compatibility with Pro Tools 2023.9+ on macOS
  • Bug fix to allow creation of a template PTX file with no ProdInfo track
Mark Franken, MPSE
Old 03-28-2024, 04:16 AM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v4.2.0 with the following minor updates:
  • New setup window for export of Text/Excel files containing all cues. Select columns to export, sort order and more
  • Added option to export all character/department files to their own character/department sub-folders
  • Added option to export a Pro Tools 'Record Session' where clips are named with cue number and cue text if selected
  • Added new data field to Header Band Design 'NoCuesPerPDF' to display the total number of cues in PDF
  • Created new 'Phrase List' window for Session/Project Interface windows to add commonly used phrases to Line/Note fields
  • To simplify the sharing of cue sessions, reasons can now be stored in clips as absolute text rather than reason tags
  • Major rework of PDF shooting script import code to allow import of more format types
  • Export of MIDI files optimised for lots of cues containing the same 'Line' text
  • During PTX export, code now inserts append tags in correct locations when cues contain long Line or Note fields
  • During import of PTX files, now read track width data correctly for sessions saved by Pro Tools 2024.3+
  • The Project Interface window 'Focus' button now works with Nuendo 13
  • Export of PDFs now compatible with macOS 14 (Sonoma)
Mark Franken, MPSE
Old Yesterday, 12:13 AM
mfranken's Avatar
Sounds In Sync
Just released #EdiCue v4.2.1 with the following bug fixes:
  • Fix to retain the existing styling of Session and Project Interface window fields when text is pasted
  • The data Timecode Rate is shown correctly when importing data from EdiCue PDFs with a 23.976 or 29.97 frame rate
  • Minor update to PDF font selection when exporting PDFs using 'Arial Unicode MS'
Mark Franken, MPSE
[IMG] code is Off
EdiCue V4 is out audiolex1 Post - Surround - Video 1 05-06-2022 04:49 AM
EdiCue v3 released mfranken Partner Announcements 13 01-05-2022 09:58 PM
EdiCue v3 - Emmy Award winning ADR cueing app major update has been released mfranken Partner Announcements 0 08-04-2019 09:16 PM
Using cues on d-comand dubtoc ICON & C|24 10 10-07-2008 03:22 AM
Multiple cues? The_Shoe VENUE Live Sound Systems 14 08-28-2008 08:59 AM
