Old 02-19-2023, 06:17 AM
Ben Jenssen's Avatar
Default Switching between PT rosetta and native
I'm getting closer to the point where I'll use my reinstatement code and get my perpetual license to PT2022.12. Especially now that SSL has released an ARM AXX update to the channelstrip and bus compressor.
I'm wondering if it's actually practical to switch between the two modes - staying on native and switching back to rosetta to access non-native plugins - and back again.
Does it cause any problems, like can they share prefs, can they use the same plugin folder content etc? Does it work or is it convoluted?
Thanks.
Old 02-19-2023, 07:14 AM
its2loud its2loud is offline
Default Re: Switching between PT rosetta and native
It just works. Nothing to worry about regarding plug-in presets, prefs, templates, track presets, etc.
Whether you work under Rosetta or Natively will solely depend on you plug-in compatibility.
Switching back and forth at this point isn’t really practical for many. It’s time consuming and cumbersome to keep opening and closing the application to work in different modes. Obviously, your workflow may differ from others and if you mostly use features and plugs that are available natively then that can be your go to.
2022.12 work by default under Rosetta. If you want to open Pro Tools natively you need to open the application’s INFO (Command+I) window and uncheck the box for “Open Using Rosetta”
Old 02-19-2023, 07:47 AM
Thanks man!
I'll be updating tonight.
I did try it when it came out, but just for a couple of days, so I know it works, good for a beta at least.
Old 02-19-2023, 08:02 AM
Just keep in mind of what doesn’t work with the Beta…in case you use any of these
What doesn’t work in the public beta version?
AIR plugins and instruments currently bundled with Pro Tools
Not all third-party plugins are supported yet—see here for the supported list
Cloud Collaboration and Projects
ICON, C24, and Command 8 control surfaces will not be supported
X-Form Audio Suite and algorithm in Elastic Audio
ReWire support
MP3 Export (Bounce and Export Clips as Files)
AAC Import
Score Editor
Chord Extraction
Full qualification on all systems/configurations
Old 02-19-2023, 08:05 AM
Thank you, yes I'm aware of most of this, and none of those are very important to me.
Old 02-19-2023, 09:30 AM
Gemylon's Avatar
Gemylon Gemylon is online now
Not by AVID (probably),
but they are all working fine using V-Control Pro.
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Old 03-25-2023, 11:28 AM
redmount redmount is offline
Hello,
"slightly" off topic and maybe stupid question but is it ok to open PTools native while using other standalone apps via Rosetta 2 ?
The OS can manage native and non native apps flawlessly ?
Just want to make sure that Rosetta is a "tool" you can assign individually without considering other apps
Old 03-25-2023, 11:42 AM
Originally Posted by redmount View Post
Hello,
Nothing to worry about here. None of this is really any different than running multiple applications at the same time without Rosetta. With maybe an extreme corner case that lots of things running under Rosetta might use a little more CPU and a little more memory and therefore load the system a little more, I doubt you'll even notice.
Old 03-25-2023, 11:51 AM
Merci
Old 03-25-2023, 01:42 PM
Eric Lambert's Avatar
Hello,
I think I understand what you might have been thinking here and it's not a stupid question at all. With some tech, opening an interpreter forces the whole machine to slow down because data is being siphoned through that lesser/slower protocol, creating a bottleneck for every function. As Darryl said, Rosetta isn't that kind of thing.
PT10 DSP/Native switching elicious Pro Tools 10 0 06-12-2013 04:10 AM
Does Pt HD Native work with Rosetta Yet K Roche Pro Tools 9 2 02-09-2011 04:41 PM
Does HD Native (9 work with Rosetta Yet ????? K Roche macOS 2 02-09-2011 04:36 PM
Does HD Native 9 work with a Rosetta yet ??? K Roche Pro Tools 9 3 12-15-2010 03:34 PM
Thinking about switching from 192 to Rosetta Bambison Pro Tools TDM Systems (Mac) 9 08-17-2008 04:40 PM
