Old 11-21-2022, 01:45 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default EdiLoad v5 has been released with new Assembly window
I'm proud to announce the release of EdiLoad v5. Here is a list of what's included in this major update:
  • New Assembly window can link location WAV files to an edit list to export all WAV channels in a PTX or AAF file
  • PTX files can be imported directly into the main window to load user or original timestamps
  • EdiLoad edit lists, AAFs or FCP7 XMLs can now be appended. See the new 'Append' toolbar button and File > Append menu
  • AAF and XML video tracks are now flattened correctly for main window loads
  • Multiple video layer EDLs can now be loaded into the main window simultaneously to create a flattened video list
  • Added new 'Scene No' and 'Take No' columns which load data directly from AAF and XML files
  • The Scene Change Track window now requires scene numbers in the 'Scene No' column
  • Added the 'Extract Scene and Take Numbers' window to extract this data from Clip Names
  • Added new 'Batch Update File Names' window
  • Export Picture Cut Track now exports a PTX file containing clip groups for one or more tracks
  • The Scene Change Track window now exports a PTX file contain clip groups or it can create a new marker track in Nuendo containing cycle markers
  • WAV File List window can now export PTX files linked to mono and poly WAV files
  • Column Transfer window contains new 'modify' functions with the option to append to data already present in column
  • Added 'Find' field to the main window to search for data in the current edit list
  • Added Undo and Redo for changes made to the edit list in the main and new assembly windows
  • Updated the Pro Tools re-conform code for compatibility with PT2022.6+ on macOS
  • macOS build is now a universal binary app (Native Intel and ARM64)
  • EdiLoad v5 stores its preferences in a new file, so EdiLoad v4 can be used in tandem
  • EdiLoad v4.0.4 can be run with an EdiLoad v5 license
Here's a video outlining the new features:
https://youtu.be/tWtfktwnk5A
NOTE: EdiLoad v5 requires either macOS 10.12+ or Windows 8+, while EdiLoad v5 licenses require a 2nd or 3rd generation USB iLok or sharable iLok license.
For more information see the EdiLoad product page.
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 12-12-2022, 09:25 PM
mfranken's Avatar
Sounds In Sync
Default Re: EdiLoad v5 has been released with new Assembly window
Just released #EdiLoad v5.0.1. with the following bug fixes and minor changes:
  • New settings window in WAV File List window to select the sort order of WAV Files (by time stamp or file name) when exporting a PTX or AAF file
  • Bug fix to load timestamps correctly while importing PTX files of rarely seen files
  • While matching edit list events to WAV files in Assembly window, match is no longer case sensitive
  • Now checks that clips do not overlap due to frame rounding for 23.976 and 29.97 FPS AAF exports from Assembly window
  • The WAV extension is now omitted when including WAV file names in an exported PTX or AAF file clip name from At the Assembly window
  • When limiting the channels that are exported in a PTX or AAF file by channel number, the values entered must now match the channel numbers, rather than be contained within
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Old 03-01-2023, 08:12 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.0.2 with the following bug fixes and minor changes:
  • Main edit list scroll position and selection is now retained when data is updated
  • Track and Roll Name filter selections are now retained where possible when edit list data is updated
  • Allow import of PTX files created by Media Composer 2022.12+
  • During PTX imports, load Scene and Take Number data from linked WAV files if WAV is present and metadata is found in WAV
  • For Scene Change Track window, update made to import PDF shooting scripts that contain hidden characters at left margin
  • Assembly window PTX file exports can now configure the clip colors from the text in various fields, not just the clip name
  • File exports that require a start TC to be set now handle lists that start at 00:00:00:00 correctly
Mark Franken, MPSE
Old 06-07-2023, 08:47 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.0.3 with the following bug fixes and minor changes:
  • PTX and AAF files can now be exported from the Assembly and WAV File List windows containing WAV files that have the same name
  • Added new match criteria checkbox 'Require Exact Match'. Check this when the match criteria is finding similar WAVs it shouldn't
  • PTX file exports that contain poly WAVs created by Pro Tools now contain clips that are named correctly in the correct channel order
  • Assembly settings, Track Name tab contains new controls to insert the WAV # as a prefix to the channel number/name in the track name
  • Assemblies can now match to location WAV files that span midnight
  • WAV library load code re-written to stop crash when folder tree contains invalid aliases
  • Modify option 'Replace Text at end' now replaces correct text in source when multiple instances are found
  • Pro Tools control script updated for new macOS Ventura System Settings window
  • Tweaked position of controls in EdiLoad windows to work with new look of macOS Ventura
  • Healing events in the main list no longer heals events that have a different mute state
Mark Franken, MPSE
Old 07-11-2023, 06:24 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.0.4 with the following bug fixes and minor changes:
  • Change to all PTX export settings windows to allow six unique clip colors to be set
  • Fix for bug introduced in v5.0.3 to allow the re-conform speed slider to set values above 100%
  • Added new 'Export Report' button to assembly window which creates a text file containing all channel names and linked WAV paths in export
  • Increased the length of the 'set channel names/nos to be included/excluded in export' text field in the assembly settings window
  • Right-click on an assembly window edit list event now displays a menu to 'Select event in main window'
  • Fix for bug introduced in v5.0.3 to assign WAV channels to PTX/AAF tracks correctly during assembly exports when the channel number is greater than 9
Mark Franken, MPSE
Old 08-27-2023, 10:23 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.0.5 with the following minor updates and fixes:
  • Added menu in Assembly Settings window - Track Layout tab, to allow filtering by channel name with text that is contained within or that equals the full channel name
  • Added 176.4 kHz and 192 kHz sample rate options for Assembly and WAV File List window, PTX and AAF exports
  • Refinements to Premier Pro XML import code to ignore unwanted graphics clips
  • Fix while loading preferences file on start up to stop potential hang in non-English countries
  • Updates to Pro Tools control code to full support macOS Ventura
  • Updates to various UI controls so they are shown correctly on macOS Ventura
  • Update to PTX import code to read new audio track widths created by PT2023.6+
  • Updated PACE license software
Mark Franken, MPSE
Old 09-21-2023, 06:48 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.0.6 with the following bug fixes and minor changes:
  • Changes required for compatibility with Pro Tools 2023.9+ on macOS
  • Minor update to ignore still images while loading AAF video tracks in the main and compare windows
Mark Franken, MPSE
Old 03-28-2024, 04:18 AM
mfranken's Avatar
Sounds In Sync
Just released #EdiLoad v5.1.0 with the following updates:
  • Media Composer 'SlipPerf' data can now be import from AAFs and handled in the Assembly window
  • 'Shoot Date' metadata can be imported from AAFs and used to match location WAV files in the Assembly window
  • Assembly settings, 'Match Criteria 1' tab, the 'Match Values' menu can now match: 'Anywhere', 'From Start', or 'Exactly'
  • Assembly settings, 'Clip Name tab', can now set Clip Name to include 'Scene No' and 'Take No'
  • Code used to re-load WAV file database now works when database is stored on NAS that creates snapshot files
  • WAV File list 'Creation Date' now displays correct time. Removed offset to GMT
  • During PTX file export, the 'Clip Colour Settings' tab can now also set the clip color by the text found in the: 'Shoot Date', 'Scene No', 'Take No' and 'Info Text'
  • During import of PTX files, now read track width data correctly for sessions saved by Pro Tools 2024.3+
  • Major rework of PDF shooting script import code to allow import of more formats
Mark Franken, MPSE
[IMG] code is Off
EdiLoad v4 released with support for AAF and XML mfranken Partner Announcements 4 05-27-2021 11:46 PM
WTB EdiLoad V3 KGraham045 Buy & Sell 1 02-22-2018 05:46 AM
EdiLoad v3.4 update released with support for UHD and new WAV File list window mfranken Post - Surround - Video 1 07-22-2017 03:09 AM
EdiLoad v3 released mfranken Post - Surround - Video 2 03-09-2015 09:27 AM
Production Assembly?? Naylorfreak Post - Surround - Video 0 04-06-2012 12:04 PM
