Old 11-12-2020, 03:27 AM
Lockemusic Lockemusic is offline
Default Deactivate All Plugins - Pro Tools Session loading speed
Guys when I deactivate all my Pro Tools plugins (holding shift while opening a Pro Tools session) the session loads extremely fast - it's a night and day difference.
Before I thought the session loading speed was related to the SSD speed of my Mac Pro 2019 (loading samples etc) however having discovered that its the plugins which cause the session to load slowly, is there a work around for this or is it purely based on the plugins as Im using a lot of virtual instruments?
I have my HW Buffer Size at 1024 and Disk Playback Cache Size set to normal (Ive tried to use different sizes but it doesn't make a difference with the cache). Im on a 16 core 3.2Ghz Intel Xeon, 160 GB ram. Cheers.
Old 11-12-2020, 06:11 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Deactivate All Plugins - Pro Tools Session loading speed
Loading instruments you are also loading their sounds / samples. There's nothing to be done regarding loading speed really unless you have all your sounds and samples are on SSD drives if they aren't already.
Think yourself lucky its not the 70s/80s! it used to be 2 hours arrive in the studio to check and calibrate everything before starting a session
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-12-2020, 06:17 AM
Southsidemusic's Avatar
Originally Posted by crizdee View Post
Chris
LOL Those were the days hahaha
Setting up the drums was a day alone and not counting all other gear that needed experts to engineer and setup! If it takes a minute or two to load a 100+ session with VI and plugins that is a really weird thing to complain about.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-12-2020, 07:43 AM
Indeed, we've become a world of people standing in front of the microwave yelling, "Come on already!"
Old 11-12-2020, 09:05 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Just enough time to get a coffee, tea or other beverage and drink it before you sit down in front of electronics.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Deactivate Plugins when Scrubbing spock999 Pro Tools 2018 2 09-10-2018 12:21 PM
Pro Tools Not Loading New Plugins SteveWitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2010 01:03 PM
Deactivate all plugins? Beauchampy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2006 11:19 AM
Deactivate TDM plugins eurosurfer Pro Tools TDM Systems (Mac) 2 09-03-2001 08:01 AM
