Old 04-25-2020, 05:27 AM
ViciousLullabyz ViciousLullabyz is offline
Default S3 as EUCON (with Dock) and AVB Interface
Just a quick technical question regarding the S3:
Would it be possible that i'd be using the S3 together with a Dock to control Pro Tools via EUCON, but at the same time also have it route connected Mics to the intergrated outputs at the back? Or does it need to be in AVB mode for that and would not allow to to have it connected to Pro Tools at that time.
The use would be to have separat audio routing capabilites while running HDX and Pro Tools, which takes exclusive control of my HD I/O.
Thank you :)
Old 04-25-2020, 12:31 PM
Oggy Oggy is offline
Default Re: S3 as EUCON (with Dock) and AVB Interface
It works as Eucon controller and AVB interface at the same time with no problems.
Old 04-26-2020, 02:10 AM
Hi Oggy
Thanks for your reply. Just to clarify:
I could switch the S3 to AVB mode, route audio to my mac and the outputs and then go back to controlling Pro Tools and all the controls are now Eucon/DAW mapped and not 'stuck' on AVB controls, while still passing audio, correct?
Old 04-26-2020, 07:12 AM
Yes!
1. AVB for Mac System audio
2. EUCON for Pro Tools Control
3. and HDX for Pro Tools
all at the same time
1 & 2 over Ethernet. Just check it you Mac is supported. It has to have Thunderbolt for AVB to work.
Old 06-21-2020, 04:25 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Yes!
My S3 arrives tomorrow, excited to play around with AVB!!
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Eucon/S3/Dock/Avid Control delay in responding feakerboo Avid S1, S3, Dock and Control App 1 04-23-2020 06:43 PM
Attention Strip on Dock and Logic Pro X (Eucon 20.1.0.50) mattrixx Avid S1, S3, Dock and Control App 0 02-24-2020 09:38 PM
Eddie.. Can you acknowledge this Dock/Eucon bug? robertg Artist Series 0 02-19-2019 10:13 AM
EuCon reliability since adding Dock LukeHoward Avid S1, S3, Dock and Control App 0 12-04-2016 03:40 PM
Eucon crashes on boot when dock is ON. domilik Avid S1, S3, Dock and Control App 0 09-10-2016 12:56 AM
