Old 04-22-2020, 07:52 PM
ProTooler ProTooler is offline
Default Updating To Catalina, Any Suggestions?
Hey Guys -
I'm getting ready to update my Mac to Catalina. Have any of you guys experienced any problems or has everything been smooth? Any advice is greatly appreciated.
Thank you!!... Bill
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 04-22-2020, 08:34 PM
Dale-c Dale-c is offline
Default Re: Updating To Catalina, Any Suggestions?
Originally Posted by ProTooler View Post
Hey Guys -
Thank you!!... Bill
Yes, stick with Mojave. So far all Catalina has done is messed 32 bit apps, split iTunes into several apps, which would have been good but it wasn't done as well as I had hoped. It's ok overall but I can't think of one thing I actually like about it.
Sent from my BBB100-1 using Tapatalk
Old 04-23-2020, 10:20 AM
Eric Lambert's Avatar
Hey Guys -
Thank you!!... Bill
The lack of 32-bit support will be the biggest hurdle. Go to About This Mac in the Apple Menu. Hit System Report, then Applications at the left. It'll take several seconds to populate. One of the columns will show you whether or not your Apps are 64-bit. Many will say "No." When you move to Catalina, you will no longer be able to use those Apps. I'd be very careful about upgrading until you're certain that you either don't need those or have solid replacements.
Otherwise, Catalina has been a solid OS in my experience. And, as always, if you can do a clean install of the OS it would be ideal. Installing over Mojave works but may not be as comprehensive as a clean install.
Old 04-23-2020, 10:29 AM
JFreak's Avatar
JFreak JFreak is online now
If you are fine with leaving all things 32bit behind, do yourself a favor and perform a CLEAN install of your system. Meaning erase your storage, install everything from ground up, do not use Migration Assassin or Time Machine, but the tedious install everything by hand copy everything by hand oldskool method.
I myself found a HUGE difference between upgraded (from Mojave) system and clean install. Well worth taking the time.
Janne
Old 04-23-2020, 11:02 AM
Thanks so much you guys. I'm glad I asked!! :)
I think I'll sit tight for a bit.
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
Old 04-28-2020, 02:42 AM
MadMarchTaffy MadMarchTaffy is offline
Newbie here, so apologies if stupid question.... I have just bought a Focusrite Solo and I am trying to get Pro Tools | First to work with that and my new Mac AirBook - this is running Catalina 10.15.4. - I think that I know the answer to this but.... from what I can gather - Pro Tools|First 2019.6 does not appear to be compatible with Catalina 10.15.4 - is this correct? Any advice appreciated - many thanks
Old 04-28-2020, 02:44 AM
JFreak's Avatar
Hi, welcome to the community.
Yes you are right, AFAIK there still is no Catalina compatible PT|1st
Janne
Old 04-28-2020, 02:45 AM
JFreak's Avatar
Compatibility info here for future reference, please bookmark
Janne
Old 04-29-2020, 12:24 AM
Thanks - any idea as to when we could expect a compatible version?
Pro Tools 12.5.2 not opening after updating to Catalina from El Capitan afreud macOS 5 02-08-2020 06:29 PM
Catalina on Mac Pro 5,1 the.engineer macOS 15 01-24-2020 06:06 PM
Updating Plan - Updating Billing address conundrum Cate_C Licensing & Accounts 0 03-26-2016 04:55 AM
Updating PACE drivers... before updating to 9.0.5 lanstrad Pro Tools 9 0 08-28-2011 07:37 PM
