Old 04-09-2018, 08:54 AM
Longcut Longcut is offline
Default PT Installation Directory
When installing Pro Tools, there is no option to choose and installation directory path. Instead, Pro Tools decides to install it to my OS hard drive by default. This is a problem for me because I use a small SSD (60 GB) for my OS (Windows 10) and I try to keep only OS files on it. I would prefer installing the application on my second hard drive, where I have plenty of space. I'm trying to avoid buying a larger SSD, which is completely unnecessary. Is there any way to choose my installation path for Pro Tools?
I'm experienced with computers and I'm hoping to get a straight forward answer. Thanks for any help. My computer specs are in my signature.
Old 04-09-2018, 08:56 AM
Default Re: PT Installation Directory
I'm new to forums, and I'm not sure if my signature is coming up on my post. Here are my computer specs...
Built Computer
MSI Z270 Pro Gaming - Motherboard
Intel i5 7600K - CPU
Sound Blaster Zx Sound Card
GTX 960 - GPU
Scarlett Solo v.2
60 GB SSD
1 TB Mechanical HD
Windows 10 Home
Pro Tools 2018.4
Old 04-09-2018, 09:55 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
The convention for macOS is to install applications into the Applications folder.
If there is an installer app running, then there is often other stuff that is installed in various location on your drive. That is where the app usually expects to find its stuff.
Only apps that don't require a dedicated installation, offer you to drag the app manually into your Applications folder from a window. But even that indicate that you have to place them into the Application.
You could manually drag an app later out of the Applications folder to a different location, but that is at your own risk if you don't know if the app requires the default location for proper operation (and updates).
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 04-09-2018, 10:26 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Pro tools is designed to have the program on the system drive and a separate drive for audio. Many of us also have a drive for VIs and samples.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 04-09-2018, 11:27 AM
BScout BScout is offline
No.
Windows does not allow that for actual applications (that are not self-contained.) They must go in the Program Files or Program Files (x86) folders. Time to get a bigger drive or move libraries/content to your other drive. Referenced libraries (sound samples, vst content, etc.) can live on another drive.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 04-09-2018, 11:53 AM
Southsidemusic's Avatar
You mean VI content. No VST in PT so no one gets confused
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-09-2018, 12:17 PM
No.
Amen. Best to get a larger system drive and be done with it. Relatively inexpensive. Besides most programs really need to be on the system drive. Out it this way - if you deviate from the usual install path and later want to update the program the updater will fail. And it's not just PT that's like this but Native Instruments programs as well.
Jack
QAPLA!
Old 04-09-2018, 12:26 PM
Yup. My bad. I just refer to them all the same... lazy for me.
Old 04-09-2018, 01:21 PM
64GTOBOY's Avatar
I found out about the NI stuff the hard way.
Old 04-10-2018, 12:15 AM
chrismeraz chrismeraz is offline
Don't even try, Longcut. Buy a bigger drive. You're just asking for trouble otherwise.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Delete old AIR Content directory? skyko AAX Plug-ins 7 10-31-2013 07:59 PM
Changing Installation Directory For PT11 on Windows MDJGunn Pro Tools 11 1 06-26-2013 03:56 PM
Kontakt 2 directory stevegalante Virtual Instruments 1 09-16-2006 07:52 AM
OSX Open Directory SteveH44 Post - Surround - Video 7 07-27-2006 07:16 AM
5.1 directory issues lupe Pro Tools TDM Systems (Mac) 0 04-15-2001 10:37 AM
