Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-12-2017, 04:28 PM
AlasdairMacdonald AlasdairMacdonald is offline
Default Could not create a new document because Permission denied (13) while creating Project
Hi, having issue with Creating the initial Protools First session..Protools First Help says: You need to be online and signed in to be able to "enable' your Protools First "first session' and after the Initial 'first session" one does not need to be Online , I have followed every conceivable correct procedure, i am fairly experienced with software etc.. i suspect 'alien' plugins , I use UAD Apollo Twin Duo, aThe aggregate device offered by Protools is fine (i use Mac I'm on OS sierra) and have plenty System.. I have Logic 10 on this machine too..
One obvious Problem is: this dialogue below..
this message comes up after i cancel the 'session creating" message stays frozen for ever!! as below...
Could not create a new document because Permission denied (13) while creating "Project Cache" while creating "Y23xnzbsoD5OauwQvQGkHa" while creating "Q6KEioqDmb-KMluBXAZlFc.ptproject".
Cannot get passed this error/message... Any suggestions??
Thanks
Old 06-19-2017, 04:20 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Could not create a new document because Permission denied (13) while creating Pro
Give this a try:
Q) Why do I get the error "Permission denied (13) while creating "Project Cache..." when trying to create a Project?
A) This is typically seen on Mac systems where permissions are set incorrectly.
Get Info on the Pro Tools folder in Documents
Set Privilege it to Read & Write for your user account. (Check the Project Cache folder inside the Pro Tools folder to make sure the change was applied)
Here is a link to the Pro Tools First FAQ page, where that was copied from.
Let us know if that fixed the issue for you.
Will
System Details
Old 12-24-2021, 09:09 AM
Oorgetuige Oorgetuige is offline
Hi there,
I recently bought a Macbook Pro (12.0.1) and downloaded Avid Pro Tools Software UPdate & Support Plan New (ESD) with my Ilock. All seems to go well - I can open old PT sessions - untill I want to create a new session. Then it saids: Could not create a new document because Permission denied (13) while creating "test".
these steps didn't help: everything was allready in write&read modus.
I don't know what to do next. Your advise is very welcome.
And Merry Christmas!
Old 12-24-2021, 09:56 AM
junkgear's Avatar
If you are using the standard version of Pro Tools, then you will not have a project cache when creating a session. Sessions are created directly in the directory specified when you create the session. You will still need read/write permission, and the instructions are the same, just apply them to whatever folder you have chosen for your sessions.
Will
System Details
Old 12-01-2023, 12:56 AM
babydjac babydjac is offline
Go to your Pro Tools folder and open terminal. Type 'ls -l /Users/yourusername/protoolsfolderlocation' It will bring up all permissions for your folder. Most likely your folder has root permissions somewhere when it should be uuser permissions. To fix this type 'sudo chown -R username:staff "/Users/username/locationwithrootpermissions' and your problem should be fixed.
Could not create a new document because Permission denied (13) while creating Victor Kennedy macOS 7 11-04-2021 05:16 AM
Could not create a new document because Permission denied (13) while creating "test" n2one Pro Tools 12 0 05-29-2017 03:04 PM
Could not create a new document because Permission denied (13) while creating chrishayes Pro Tools 11 23 05-27-2017 05:10 AM
Just installed PT 12.5.0, get "Permission Denied (13)" error when opening. Got2ReturnVideoTapes macOS 2 08-07-2016 11:06 PM
Processing Audio - Permission Denied (13) rogerhavoc Avid Cloud Collaboration 0 04-11-2016 12:10 AM
