Re: PT's dual low latency buffer, 110 instances of Kontakt 'n stuff.
No, this has nothing to do with delay compensation.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
This AVID video must be BS? Or, I am doing something terribly wrong and/or misunderstanding that'a going on here....? - I'm midway through a mix. As an experiment I've deliberately frozen all instruments and committed all Elastic, so only audio tracks are running. I've disabled Melodyne. There are no tracks in input monitor/record ready. So, if I understand correctly, I should be able to set the H/W buffer to 32 samples and it not affect playback at all......? .... Have I missed something? - - https://vid.me/OJnP |
The way I understand this, the playback buffer on all audio tracks in playback is internally set at the maximum buffer for the sample rate you are using. Tracks in Record are set by the user in the Playback Engine drop-down menu. For Instrument Tracks, both Playback and Record are set by the user.
When a VI track is Committed, it is treated like an Audio Track. I hope this helps.
#16
You are missing the other part of the equation. The buffer size also dictates how Pro Tools is prioritizing your CPU distribution. At a low buffer, the CPU is being prioritized for latency, as the buffer gets higher, its being prioritized for power.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#17
Are there any Instrument Tracks in the session you posted? And then, there's Steve's new post above mine.
#18
There were frozen instrument tracks, but I tried committing them to straight audio tracks and it still did the same thing.
#19
Then perhaps there is much more going on here than the simple Avid explanation implies.
#20
BUT the AVID vid claims that you can set a low buffer without affecting other playback tracks at all....? "This allows the user to get the lowest possible latency without having to constantly adjust the buffer or the session"
How many instances of Kontakt can you run in the new pro tools HD 11? | Meccanizm | Pro Tools 11 | 5 | 04-10-2013 11:42 AM |
Anyone using Kontakt 3 or NI Stuff With PT8 And Getting By? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 12-17-2009 01:53 PM |
This buffer stuff is making me mad. | meltdown5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-25-2006 10:45 PM |
Buffer Issues and other stuff | sainsomnia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-19-2006 12:44 PM |
New section for Dual monitor stuff | Ray Fabi | Pro Tools TDM Systems (Mac) | 1 | 04-18-2001 10:41 AM |
