Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 06-02-2016, 12:08 PM
bspaceman bspaceman is offline
Default Re: Midas M32
Hey folks, rehashing an old thread here. I have been asked to record from a Midas m32 to protools 12.4.0. Using a MacBook Pro Retina 13" El Capitan.
I want to be clear on this as I have never done this before; Did you simply plug your macbook into the back of the Midas 32 via USB and the Midas came up as playback engine? Is that all I would need to do to make this happen? Would I need my MBox Pro 3 there or could I simply go from the back of the board to the mac for recording only and then edit later back home? Does the Midas need to be configured to do this or is that USB in the back an automatic 32 out?
Thanks for your help!
Old 06-02-2016, 02:38 PM
YYR123's Avatar
YYR123 YYR123 is offline
With the X32 I just plug it in...and then setup my pro tools playback engine to the M32.
My X32 needed to have the drivers loaded onto my laptop first.
It's pretty easy, or at least should be.
Daniel
Old 06-02-2016, 07:38 PM
Indeed^^^ I recently did a live recording with a semi-old MBP 13" with PT12.5. I connected, fired up PT, selected the Midas as the "audio engine", went to the IO setup page>Input tab and hit the default button. Created 32 audio tracks, put them into record-ready and hit the spacebar. Away it went for a good 90 minute show on a small USB3 external drive
Old 06-03-2016, 12:02 AM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
It's an astonishing little desk. Ran into a pair of them this week in a largish church. They don't have full interactivity as a pair (can't share pfl control) but you can certainly use one to sub into the other. Quite a powerful FOH system.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
Old 03-03-2017, 09:31 PM
dyoung72 dyoung72 is offline
Need some help! M32 to Pro Tools 12.7. No issues with connectivity or sound quality while recording. However, everything comes out to the same tempo after it is recorded no matter slow or fast song. I feel like there is a buffering issue or setting that is messing up the recording. Recording on a MacBook Pro i7.
  #16
Old 03-04-2017, 12:04 PM
YYR123's Avatar
I would trash prefs and try again.
B/c that's way too weird.
Check the sample rate settings, the X32 only has 44.1 and 48k.
Daniel
  #17
Old 09-11-2018, 03:02 AM
xrekcor's Avatar
xrekcor xrekcor is offline
anyone using this desk (M32) with High Sierra 10.13.6 and 2018.7? giving this desk another look.
sorry if this is restarting an old thread, not sure if there is a rule about this, just as this thread is similar topic and didn't want to start another thread
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
  #18
Old 09-11-2018, 03:22 AM
xrekcor's Avatar
also do guys know if the X32 and M32 run the exact same software?
Rob
  #19
Old 09-12-2018, 12:18 PM
Not exactly sure what you mean here...do you mean internally? In any case, I believe the answer is yes and for 2 reasons. #1-Midas assisted in writing the code that Behringer used(the X32 was released way earlier than the M32). #2-the 2 iPad apps both will run either console(I tend to use the Midas version because it looks a little better, but both have exactly the same functionality)
  #20
Old 09-12-2018, 01:19 PM
xrekcor's Avatar
thanks Dave..... do they still call you Dave.... I'll just call you Dave.... sorry couldn't resist.
thanks for your reply, a few days ago I watched a demonstration video on the 2 units and the chap on there said the software was basically the same.
Rob
Midas F32 Connection to Pro Tools HD 10&11 The Phillips Project LLC Third Party Interfaces 17 02-12-2016 02:58 PM
Midas snake-MADI Nicolas Lowman VENUE Live Sound Systems 2 07-02-2010 05:24 PM
Behringer just bought Midas and Klark Teknik. Alιcio Costa Pro Tools TDM Systems (Mac) 15 12-11-2009 07:13 AM
Analog Consoles, ...Soundcraft or Midas? Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-07-2002 08:39 AM
