Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-05-2015, 10:05 PM
simon lefisch's Avatar
simon lefisch simon lefisch is offline
Default Re: Digi 002r and OSX Yosemite working
Originally Posted by drguitar View Post
Not saying you were! Just making sure anyone reading this doesn't take it as meaning that Pro Tools will also work with that version of the driver and the 002/003 interfaces.
Gotcha
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5
Old 01-08-2015, 12:37 PM
JohnMolina JohnMolina is offline
Hi Simon question so by deleting all the protools files does that mean protools itself will be deleted to where I won't be able to access protools to record.
Old 01-09-2015, 08:47 AM
I believe so, however you should be able to reinstall PT and pickup where you left off.
Again this is all speculation as I don't use PT. I'm only using my 002r interface to work with logic/ableton (as i mentioned in the OP). You would have to try it out yourself or maybe someone else who uses PT can chime in.
Old 01-31-2015, 11:57 AM
davidk1023's Avatar
davidk1023 davidk1023 is offline
Where do you get the 10.3.3 drivers?
Old 01-31-2015, 03:09 PM
http://goo.gl/jkAeSC
  #16
Old 03-18-2015, 04:48 PM
davidk1023's Avatar
Thanks Simon! it worked! but now I can't record my midi notes into logic. I can hear the sounds from my midi keyboard into logic, but it won't record. Can you help me?
  #17
Old 03-18-2015, 05:26 PM
Are you using a midi keyboard with USB or are you trying to use the midi inputs on the interface? If the latter, not sure it will work. I use a USB keyboard or I use an external midi interface (Midisport 8x8/s).
  #18
Old 03-21-2015, 11:58 AM
nnaco nnaco is offline
Hello All,
I have been reading this issue all over the internet. I have Digi Rack002, Logic Pro X and Yosemite, all latest version (21st march2015).
Trying to find a solution to make my dinosaur Digi002 work with this system. I am almost convinced that I had to buy new interface.
I have tried everything that I have read on internet , nothing worked.
UNTIL,
I have decided to give it a shot to the latest version of the driver with no hope
http://avid.force.com/pkb/articles/e...02-003-Drivers
yes, the one it says Digi 002 Console and Rack not supported (untested) (V11.1.3)
And yes IT IS WORKING
just select Avid 002 Rack from your system. that is it. everything works. logic, iTunes live, etc, all systems go.
so I still can keep my old Digi Rack002
  #19
Old 03-21-2015, 04:24 PM
Default Digi 002r and OSX Yosemite working
Originally Posted by nnaco View Post
Hello All,
UNTIL,
That driver does work, however you'll notice that when you have the interface plugged in, kernel task shoots up in cpu usage (unless they recently updated the driver). You can see it in Activity Monitor. The 10.3.3 driver does not have that.
Read this thread:
http://duc.avid.com/showthread.php?t=362053
Looks like at the end of the thread their maybe a fix, although I think I tried that and the issue remained.
  #20
Old 03-29-2015, 07:28 PM
davidk1023's Avatar
simon lefisch
actually I'm using a korg triton studio as my midi keyboard. I also have a mpc 2500 and 2 other sound modules. i get the sound coming into logic when i use software instruments, but i can't record the sound from the midi instruments. maybe i have to figure that out in the midi environment or something.
OSX Yosemite and Digi 002R guitarplaya1423 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-04-2014 01:30 PM
MBOX 3 mini not working on Yosemite Raden Agung FireWire & USB Audio Interfaces (Mac) 2 11-20-2014 09:58 AM
DIGI-002R S/PDIF not working socko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 12-05-2010 09:44 PM
Sia Smaart and Digi 002r not working!?! Andi R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-21-2005 08:03 AM
Digi: 002R Clicking but not working JKD99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-30-2003 08:21 PM
