Backup Plan Questions
I've been reading the thread on having a backup plan and I realized I needed to put together my own backup plan, but I have a couple of questions before I start. First, can I use any hard drive, or does it have to meet certain specifications? I know that Avid recommends using certain kinds of hard drives as audio drives, but I haven't seen anything yet on hard drives for backup. Second, how often do I need to backup my system/ when should I backup my system? I am just starting to use Pro Tools to do some basic home recordings, so I don't need the most complex backup plan. I'm not a professional, I'm just doing this as a hobby. Any advice is greatly appreciated.
iMac w/ OS X 10.8.3, 2.5 GHz Intel Core i5, 8 GB RAM PreSonus AudioBox USB Pro Tools 10.3.5 Glyph GPT50 external hard drive |
Re: Backup Plan Questions
For the simple backup of data (e.g PT Sessions, Audio, Samples etc), Pretty much any HD should work.
If you are talking about backing up your system (Operating system, programs etc), then you need to be able to boot from the backup / cloned HD . In which case it needs to be Firewire as USB won't work. |
the best is to backup on a cloud like dropbox. if you store the backup in the same building as the original, it's not safe (fire, burglar...)
use synctwofolders to synchronize your backup regularly (every hour e.g.): create a folder like "backup" (on a different drive) which you copy to a cloud e.g. with dropbox and use synctwofolders to synchronize your project folder with "backup". Do not use your project folder as a dropbox folder!!! You have the folder "backup" on a different drive as a simple copy and the cloud for worst case. |
I have multiple drives hooked up to a Mac MINI that sits in a bedroom closet... 1TB, 2TB and 3TB. The MINI is running Retrospect and has 'scripts' to backup all of the computers in my house... all UNATTENDED!! It's a GREAT app, and can do a HUGE amount of varied things.
The cloud services are OK, but you need to remember you're talking about HUGE amounts of data being moved through your internet account. It can take FOREVER, depending on your upload speeds. You can get Retrospect for as cheap as $119 for up to 5 client machines, as well as the server. Info at http://retrospect.com/en/products/mac
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
I've lucked out up here as 'staples' has a clearance sale on USB 3 drives from sea gate, 500gb for $29. I bought six! As our friend Albee would say "if it's not backed up 3 times, it's not backed up!"
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Get a drive and enclosure from a reputable mainsteam manufacturer. Think about use of Carbon Copy Cloner (or similar) to make image backups of your boot/system drive. The first step of a backup plan is to work out *why* you are doing this. What are you trying to protect against? Admin errors? Theft? Malicious damage? Hard drive failure? Entire PC failure? Building failure? And/or are you trying to do long term archive/recovery of sessions, etc. And put in place a plan that can achieve those goals. And then find a way to test if what you are doing actually works. |
Sparky Last edited by Sparky1; 09-07-2013 at 11:14 AM. |
At my previous studio we backed up audio projects to a network shared file server that was 16TB mirrored so it was backing up the local backup again. We also ran crashplan pro on each audio machine backing up to 'the cloud' nightly. We had a 100mb up and down Internet connection which made this possible.
Have a Backup Plan. Regardless of platform | sunburst79 | Tips & Tricks | 55 | 03-07-2017 08:19 AM |
switch to OS X backup plan... | simone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-20-2004 08:40 AM |
A couple of final external backup drive questions. | Siberian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-04-2004 03:05 PM |
Rail, questions about MacDrive & CDR/DVDR backup | Oz-boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-22-2003 11:25 PM |
Questions about the old DAT-A backup... | Nexxt | Pro Tools TDM Systems (Mac) | 2 | 06-03-2003 07:02 PM |
