Old 07-15-2013, 02:30 PM
BroomPole BroomPole is offline
Default Dialnorm Conform -24LKFS
Hello All,
I'm in the process of auditioning some software for automatic -LKFS conforms.
This is not for use for things I am mixing however much of my work involves prepping assets for VOD delivery. In the last year some clients have started asking for audio to conform to -24 LKFS standards.
Without having time / money to go back and remix to match I have found a few pieces of software that can process files and auto correct (Not Ideal I know but it will have to do).
Do any of you have experience with any of the two below or can recommend one not on my watch list.
Either Pro Tools Plugin or Standalone.
NuGen LM Correct
VidChecker Audio Tools
Thanks for any feedback.
cheers
Kevin
Old 07-15-2013, 02:53 PM
Peter Cole's Avatar
Peter Cole Peter Cole is offline
Default Re: Dialnorm Conform -24LKFS
Originally Posted by BroomPole View Post
Hello All,
NuGen LM Correct
cheers
Kevin
I have the Nugen LMB software. While it does the job of passing QC, nothing beats Good metering (Nugen) and hand riding your project into spec. It really doesn't take too much time to do it right.
Old 07-15-2013, 03:24 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Nugen LMB is designed for batch correcting a whole bunch of files, LM-Correct would probably be the go as it is simple to use as an audiosuite plugin (or a standalone app.) PT11 ready as well. A good meter is also worthwhile to get you in the ballpark before you use something to correct the file ie: Nugen VisLM or say TC LM2 radar meter.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 07-15-2013, 07:22 PM
philper philper is offline
A quick trip through Audition CS6 can do this. You'll have to decide for yourself if you like the sonic results.
philp
Old 07-16-2013, 06:51 AM
@Peter Cole, thanks for the feedback, this is for delivered HD video masters which I have no access to mix sessions.
I would be properly metering for sessions I am mixing.
So if it passes QC that's really all I"m looking for.
cheers
Kevin
Old 07-16-2013, 07:02 AM
Peter Cole's Avatar
cheers
Kevin
You can set up a batch process once you have tuned your delivery specs inside LMB. Set up a "Watched folder" and anything you drop into the folder will be processed.
Old 07-16-2013, 07:10 AM
nucelar's Avatar
nucelar nucelar is offline
I would go for a standalone solution that allows batch processing.
Nugen LMB, Grimm Audio Level One or Twistedwave are nice solutions.
Make sure it recognizes split monos as stereo or surround mixes and it provides a limiter in case a positive offset generates overs.
Old 07-16-2013, 03:17 PM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Nugen - does what it says on the tin.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 07-16-2013, 09:13 PM
alexeymohr alexeymohr is offline
I would recommend against any type of "auto-leveling" processing, as the sonic results typically aren't super-pleasant.
A much better workflow is to get a metering plugin that measures according to the specific standards that your client requires (1770-1, 1770-2, or 1770-3) such as the Dolby Media Meter or Waves Loudness Meter. Then measure your mix in the time window that your client requires (some require that each act meets spec, others only require that the entire duration of program meets spec).
Then just trim your comp mix up or down by however much you need in order to get it in spec (which is normally -24 dB LKFS). For instance, if act 1 measures out to -22.5dB LKFS, then trim it by -1.5dB. If act 2 measures to -25.7dB LFKS, then trim it by +1.7dB.
This way you're perfectly in spec, and nothing is messing with your mix in terms of dynamics.
- Alexey Mohr
https://www.parkstreetpost.com
Old 07-17-2013, 11:50 AM
Thanks for the feedback alexeymohr. I do use WLM on mixes I am performing.
This is for finished TV / FILM HD deliveries that have no money / time to go back to mixing and I only have access to the 5.1 PrintMaster
HTML code is On
converting from -20dBFS to -18dBFS and staying at -24LKFS PostGuys Post - Surround - Video 4 09-12-2013 03:31 AM
Dialnorm-WLM or MediaMeter? subwoof Post - Surround - Video 27 11-18-2012 04:04 AM
dialnorm at -31?? Taddy Post - Surround - Video 24 10-29-2006 09:28 AM
dialnorm at -31?? Taddy Post - Surround - Video 0 10-26-2006 02:58 AM
auto conform but no Post Conform Richard Fairbanks Post - Surround - Video 5 03-21-2004 10:35 AM
