#41
Re: Have a Backup Plan. Regardless of platform
200gb???? Do you not clean out bad takes and unused files???? 10 song album will avg around 80-90gb at the most for me at 24 bit.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#42
I´ve used for years Retrospect 6 on my G5, which works fairly well by making backups to DVD. After going to a Mac Pro I tried the new version, since Retrospect 6 isn´t supported to run on an intel mac with snow leopard. So I tried the new version Retrospect 10, which I removed after 1 day full of bugs and trouble. It´s ridiculous what they made out this piece of software.
Does someone know an alternative to Retrospect, that also uses optical drives (DVD) for incremental backups ? thanks in advance
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#43
Thanks
AJF Now: MacPro Tower OS 10.8 - PT2018- MBox Pro - MACKIE preamp for monitoring only - mostly WAVES PIs - a couple of AKG/Shure Mics - MAudio Key49 Up Next: Mac Mini M2, PT 2023.9, Focusrite Solo - I love this set up! It's faster than I could have hoped for. Then: ProTools 5-ish digi001 on a PC running Windows Millennium BD (before digital)-from Tascam 8-track to Neve 64 - ran live audio for Club 88 in LA (Decline of Western Civilization) and Stage East in N Hollywood "...this puts things into perspective...too much ****** perspective..." David St Hubbins and Nigel Tufnel standing over Elvis' grave. |
#44
Is it OK to save the clone to the same external drive that I'm using to record my pro tools sessions to? Or do I need another external drive just for clones? Also what is the difference between a disk clone and disk image? The Pro Tools Software Installation Guide recommended saving an image of the system drive but it seems like most users here create disk clones. Can someone explain why?
iMac w/ OS X 10.8.3, 2.5 GHz Intel Core i5, 8 GB RAM PreSonus AudioBox USB Pro Tools 10.3.5 Glyph GPT50 external hard drive |
#45
A clone and an image backup are referring to the same thing.
Having a clone saved on an audio drive is fine and many of us here will do that. But the danger there is that copy is always online and with the computer. You can accidentally delete it, or if the computer gets zapped or catches fire or stolen,... Well where is your recovery image? So a good pan will also involve offsite backups (clones or other types) e.g. put in a persobal deposit box, or just taken home from the studio and/or having backups in an onsite fireproof/waterproof safe. Any plan starts its working out what oh are trying to protect from. Admin finger accidents? bad software updates? disk failure? total computer failure? fire? water? total building failure? theft? malicious employee tampering/destruction? etc. And once you think you have a plan and backups go test trying to restore them. That usually needs a few spare drives but well worth that cost. Be very very careful not to damage things when doing this test, take the other drives offline etc. or recover to a separate computer if you have that luxury. I have seen more than a few companies IT system recoveries fail when needed... never pretty. |
#46
#47
Sony Optical Disc Archive standalone drive unit, does anyone tried the Sony Optical Disc Archive?
This have some limits, only archive 60.000 files and the data transfer with verifications can only record at 5.5Mbs without goes to 10mbs, but giving you access to your content for 50+ years, for reading speed is USB3.0. We have 10TB to make backups and archive is there better solutions than this? Each Project is about 1.3TB. What I've done was delete all fade files from our Save Session's copy in... and zip without compression each episode (using automator and script). Now I only have 4.000 files instead of 129.000 files for each project. The IT team says that Hard Drives are not reliable solution for archiving. I gave them the two 2TB HDDs solution for each project, one HDD master and another HDD clone of the master, if one fails we have the other to make another clone. Faster and inexpensive solution. They say is a no go solution. Regards, Marco
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
#48
HDD's live a lot longer if they are powered up every 6 months or so. Or so I've heard. At the semi pro level I would probably recommend something like a always on RAID file server and optical backups plus a set stored off site. BlueRay disk may be a better option for you than other optical media. I would try to avoid anything in a proprietary format if at all possible. Tchau
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#49
Thank you. Regards,
#50
I can't really remark on the Sony optical solution. It looks like it might be a good fit but you really would need to talk to some familiar with enterprise level backup systems in order to assess the long term viability of that solution.
The story of Mezzo backup is a familiar one for Pro Tools users in regards to proprietary solutions. It was popular and then the company folded leaving some folks stranded with backups they could not read.
Backup Plan Questions | jhonkaman | macOS | 11 | 09-10-2013 12:32 AM |
003 any upgrane plan? | bonzerboy | General Discussion | 2 | 03-06-2012 06:54 PM |
Vantage plan and 003 Need Help | KroNEe | Pro Tools 10 | 5 | 01-10-2012 03:46 PM |
switch to OS X backup plan... | simone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-20-2004 08:40 AM |
TRAVAN Tape Backup - compress audio backup or not ? | stoneinapond | Pro Tools TDM Systems (Mac) | 2 | 11-28-2001 12:35 AM |
