Old 11-18-2012, 10:07 AM
Patrick H Patrick H is offline
Default Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but
HI All,
I hope some one can help me here. I recently installed PT9 and it was great as I didn't need to have the audio interface plugged in to use the the PT software.
THEN, I decided to record some stuff and I need to use the mbox. As the Avid site says, you should install the drivers after installing the PT software, however; after installing the drivers the PT software would boot up and I get a long report error and the following reason on it:
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0
The strange thing is that I DID install both PT9 and then PT9.0.6.
Cn someone advise why this is?
Thanks - Patrick
Old 11-18-2012, 10:08 AM
Default Re: Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later,
I should have mentioned above, this was when installing on a macbook air running OSX 10.7.5
Old 11-19-2012, 05:58 AM
crizdee's Avatar
crizdee crizdee is offline
Trash all prefs first..
Delete Pro Tools preferences.
-Go to Users > “your user name” > Library > Preferences
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
-Empty trash, then restart the computer.
Then uninstall and reinstall Pro Tools...
-Run the Pro Tools installer from your CD-ROM or web download.
-Click on the Custom Install menu and choose "Uninstall".
-Click continue and then choose the option for "Clean" uninstall
-Click OK when it reports that the uninstall was successful and then reinstall Pro Tools.
Then the latest version of 9
Then the latest driver for the interface
See if that works
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-20-2012, 02:46 PM
Hi Chris,
Thanks for your response. I can't find the user files on the Lion OS? I clicked on Users & Group Preferences on the top right of the screen near the spot light option, but could not get into the system or library folders. I also search for all the file names you mentioned in your first step, in spotlight and in a system window search bar but no results.
I hope you can provide some further assistance. Cheers - Patrick
Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 Danishan90 macOS 10 02-10-2014 03:11 AM
This version of Strike requires authorization for you to use it. jackshocklee Virtual Instruments 6 01-12-2011 10:56 AM
Incompatible library version: CFnd provides version 7.2.0 heshion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2009 03:42 PM
This version of Pro Tools requires DAE version 5.1 or later. Josh Jagdfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-09-2007 03:31 PM
"This version of ------- requires authorization" ? tamashii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-04-2006 07:30 PM
