Old 11-02-2009, 05:59 AM
Applebee Applebee is offline
Default Will This Work?
Hi.
I'm about to purchase a used HD system with Version 8. I'd like to run 7.4. Do I need to purchase a 7.4 license, or will the version 8 auth work backwards?
Thanks.
Old 11-02-2009, 06:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Will This Work?
Originally Posted by Applebee View Post
Hi.
Thanks.
Ilok auth for 8 will not auth 7.4
Producer, Engineer,
www.ukmastering.com
TCDet TCDet is offline
....need to purchase a 7.4 license
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
The plugs that WORK and DON'T WORK on 7.0 The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-10-2006 10:12 PM
New Mic won't work DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2002 09:06 AM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
