Old 10-31-2009, 08:44 AM
Loudyman's Avatar
Loudyman Loudyman is offline
Default Tools advice for 192 I/O calibration
Hey guys,
I want to calibrate my recording chain and I wonder which tools I need for this purpose ?
I know that in the 192's manual , digi recommend to connect an external VU meter and align the outputs to read "0 VU" on it (while sending a signal with the desired calibration level)....
But, my question is :
As I don't have any mixing console ,just preamps and an incoming monitor controller , how can I calibrate the 192 ?
-With an AC voltmeter and use the old calibration method ?
If so, could you tell me which one to use please ? (reference or things I should know on them are welcome as I know nothing on this kind of instrument )
or
-Buy a VU meter only for calibration ? (this one seems to be a nonsense in this case )
or something else ?
Thanks in advance.
Mac Pro 8 cores Intel Xeon harpertown 3Ghz (Early 2008)| ATI radeon HD 2600 XT | 16GB RAM | 750GB system drive + 3x1TB drives |
MAC OSX 10.6.8 | Protools HD 10.3.2 |
HD3 PCIe Accel |
192 I/O |
Old 10-31-2009, 10:47 AM
Default Re: Tools advice for 192 I/O calibration
http://duc.digidesign.com/showthread...ke#post1451169
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-31-2009, 12:02 PM
Sean Russell Sean Russell is offline
That's a bit more convoluted then it needs to be.
Get a small screwdriver, and a DB-25 -> DB-25 cable.
I usually un-rack the 192, and get it so I can see the mix window and the 192 in front of me.
Plug in Digi-Link and Power to the unit, and connect the DB25 output to input on the card you want to cal, and put PT in the cal mode..
I use the Digi Template for the 192 cal and sometimes have to change the -18 to -14 (in rooms that have a 96 i/o and/or 1622 in addition to the 192).
The rest should be as is...
HTH!
... but does it help the chorus?
Old 10-31-2009, 05:19 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
BAD advice, you can not calibrate the output to input.
You calibrate the input with a calibrated output.
Do not use a VU meter to calibrate unless you know the VU meter has been calibrated first
To the OP, use a voltmeter, 1.228 VRMS across pins 2 and 3. Using the signal generator at the operating level you choose, then you can calibrate the input using the calibrated outputs. At that point you can then calibrate your VU meter.
Old 11-01-2009, 04:05 PM
TCDet TCDet is offline
"You calibrate the input with a calibrated output."
Yes outputs first (Just like Tape but with a few less tweaks n tones)
I bring a spare video monitor (in order to see ProTools) to the back of my rack. My meter of choice is a calibrated Fluke 867B.
(There are other (Many) choices for no load RMS meters)
Calibrate your outputs (I use RMS 1KHz at -18 DBfs Work dependent)
If unsure then hire a tech you feel comfortable with.
After checking / or re-cal I usually check my Audio Monitor calibration. Same tones for voltage to amps (all PB muted) then Pink Noise for SPL levels.
I would generally do all the above after a change to my control room environment or any new changes to my monitor chain.
From there a rough check every now and then off the patch panel.
Once all is done.......
Old 11-04-2009, 02:26 PM
Loudyman's Avatar
Thanks for the replies ,
As I also need an SPL meter to complement my ETF software for room measurement, do you think that a box like the Phonic paa3 will do it ? or it's a toy ?
It does SPL, dBu, Voltage, Rta, rt60 measurements ....
And I'll use it for the 192 I/O calibration as well .
I ask this cos' I can't find a good SPL meter and the "classic" Radioshack that everyone seem to use is not available in France ...
This way I kill two birds with one stone.
Any thought ?
Loudy;
HD3 PCIe Accel |
192 I/O |
Old 11-21-2009, 02:51 PM
Loudyman's Avatar
Then, no opinion on the Phonic Paa3 ?
HD3 PCIe Accel |
192 I/O |
Pro Tools 10 and CPT Advice! dRolan Pro Tools 10 22 11-14-2012 04:46 AM
Pro Tools HD guy needs some LE advice please Louisblanc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-09-2010 07:43 PM
i need help please!!! i need advice!!! PRO TOOLS jale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-26-2009 02:11 AM
Help and advice pro tools le 8.0 moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2009 08:57 PM
Where do I get Pro Tools Calibration Tool? mmyers Pro Tools TDM Systems (Mac) 3 08-11-2002 05:37 AM
