Old 10-11-2009, 08:34 AM
acmost acmost is offline
Default 8.01 and Edit Window/Color Question
I admit it, even though I've had PT 8 since it came out I've been using 7.4 on another drive with a separate OS, mainly because I like the white in the edit window...puts me in a happy place but I just downloaded the 8.01 update & am determined to make it work.
So...is there a way to adjust the color of the actual Edit Window background? Not the color palette that changes the Mix Channels & Region Colors but the actual grey/gray color of the Edit Window?
Thanks!
Old 10-11-2009, 10:22 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: 8.01 and Edit Window/Color Question
no
Producer, Engineer,
www.ukmastering.com
Old 10-11-2009, 10:45 AM
dtrusz dtrusz is offline
you get used to it. Seemed busy to me at first too but you'll grow to like it.
Old 10-11-2009, 10:49 AM
TCDet TCDet is offline
However the saturation lightens up enough for me to keep it colored but bright.
It's a fine line but you do get use to it (Or I did).
Generally pretty solid on a PPC DP2.7 PT's HD8.0.1, Laptop-SL LE 8.0.3
Old 10-11-2009, 11:01 AM
studiojimi's Avatar
studiojimi studiojimi is offline
right...and you probably enjoy root canals too?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 10-11-2009, 11:25 AM
Hey thanks for the reply all.
The saturation is only on the Mix Window and the little colored track portion on the left of the edit window...not the edit window background. Itdoesn't change the grey at all.
Issue with Track Color in Edit Window robinbjerke macOS 8 05-25-2018 06:22 AM
mix/edit window question thruhiker Windows 2 11-19-2012 05:55 AM
Question on Edit window. joesackic Windows 4 03-01-2011 10:29 PM
How do I get color back in edit window? jjboogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-31-2009 11:11 AM
Color coding regions in Edit window? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2001 01:37 PM
