Old 08-14-2007, 09:10 AM
Maxheadroom Maxheadroom is offline
Default Audio Files cut off on import
I've the problem when importing mp3 files into pro tools that nearly the last second of the file is missing- cut off!
When I listen to the audiofile in the import window it sounds normal and is not cut off...
Does anyone know how to fix this problem?
Max
Mac Pro 2,66 Ghz, 5GB RAM, Digi 002Rack, OSX 10.4.9, PT LE 7.3.1 cs 4
Old 08-17-2007, 12:50 PM
Yanmonster Yanmonster is offline
Default Re: Audio Files cut off on import
I've had this problem as well. What I do is convert the files to wav then import them into the session. If you don't have a file conversion program you can use itunes. Burn the track(s) to a cd. On your itunes preferences, go to advanced and select import. You can then change it to import it as a wave file. Import the track(s) from your cd into itunes and then you will have them as wav files. You can then import the wav file into your PT session without having the end cutoff.
Hope that helps.
Old 10-13-2023, 12:01 PM
CBaudiopost CBaudiopost is offline
Max
So 17 years later and I'm having the same problem! Checking mastered files of an Audiobook, need WAV and MP3 versions, in the finder my WAV and MP3 file are both 37:06, when imported back into PT, the WAV is fine but the MP3 has now randomly lost 3 seconds! Very weird.
Import Audio Is Not Copying Files To My Audio Folder zwatrif Windows 12 11-14-2017 09:32 PM
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
can't import audio from xd cam HD MXF files Echotone Post - Surround - Video 0 11-06-2012 03:36 AM
Import Audio not 'saving' to audio files folder.. prkm123 Pro Tools TDM Systems (Mac) 5 07-18-2011 02:31 PM
Can not import 5.1 audio files??? geoff6 Post - Surround - Video 1 11-30-2001 12:20 AM
