Old 01-21-2020, 04:48 AM
Default Re: Plugin directory security weakness - check your plugin directory permissions
Terminal commands are there in the code blocks. Basically if you don't understand what is going on in there, don't do it. Whatever you do in Terminal, especially when someone says you should "sudo" something, you need to know what you are doing and not just simply follow instructions.
I know what I'd be doing but usually when someone references using Terminal they'll say to input such and such.
Old 01-21-2020, 04:50 AM
well the first post says you can check permissions by listing "ls -ld" and changing permissions by "sudo chmod" so just go from there
Old 01-21-2020, 04:53 AM
Thank you for the quick reply.
Old 01-21-2020, 04:54 AM
np
Xpand directory for PT First headlap Pro Tools | Intro Discussion 5 11-14-2018 06:09 AM
PT Installation Directory Longcut Pro Tools 12 9 04-10-2018 12:15 AM
OSX Open Directory SteveH44 Post - Surround - Video 7 07-27-2006 07:16 AM
Alternate DaE plugin directory for pro tools GamerGee Pro Tools TDM Systems (Win) 1 06-06-2006 05:17 PM
5.1 directory issues lupe Pro Tools TDM Systems (Mac) 0 04-15-2001 10:37 AM
