Old 10-23-2010, 09:40 PM
100595 100595 is offline
Default Microsoft Visual C++ Runtime Library Runtim Error R6016
I keep getting this error message while trying to open a project in Pro Tools
I have a 1.36TB HDD, Intel Core2 Quad CPU at 2.67GHz, and 4.00GB of Ram. I'm running Pro Tools LE 8 through an 003 on Windows 7 64-bit. I updated the drivers less than a week ago.
Although it may be unrelated my computer's also been freezing a lot when running large projects. I can fix this by switching off my 003 interface and restarting it after closing Pro Tools. Perhaps I need to purchase some more RAM; I do run a hefty amount of natives
Old 06-17-2011, 11:37 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Microsoft Visual C++ Runtime Library Runtim Error R6016
I have this anoying problem to.
Trying to insert VI's (e.g Mini Grand, etc) into intrument tracks.
PT9.0.3 freezes (not the PC).
I can shutdown PT9 from the Task Manager in Windows 7 Ultimate, but I have to restart the computer to get PT up an running again.
Anybody else have this problem too ?
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 06-17-2011, 02:15 PM
You wouldn't happen to have any ReWire Clients patched in? This link might help.
Aaron Mulqueen - 001 HD Native
Old 06-17-2011, 04:24 PM
chrisdee's Avatar
No rewire here.
Thanks for the link. If the problem persists i will try that solution.
Old 06-17-2011, 05:02 PM
JMS40 JMS40 is offline
Try trashing the database folders on each of your harddrives.
Old 06-18-2011, 02:02 AM
TCM's Avatar
TCM TCM is offline
This error may also be caused by incompatible Plugins.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 06-18-2011, 06:10 AM
chrisdee's Avatar
I guess you are correct. I removed CRS reverb from IKmultimedia and bombfactory BF76.
I have not had the error message after that.
But I'm not knocking on wood yet.
Old 06-18-2011, 01:41 PM
RiF RiF is offline
Same here (since 9.0.3... or any plugin install same time...). Lately, I installed PT 9.0.3, Soundtoys Devil-Loc Free 1.0.2 (causing Access Violations pretty often), Waves MPX Master Tape (from Waves V8r7) and UAD 5.9. No idea, what's causing this. I have the Devil-Loc and the MPX in focus...
Old 08-19-2011, 03:54 AM
chrisdee's Avatar
I can't see any bug fixes in the readme file but It will be interesting to se if 9.0.5 solves the dreaded R6016 error that makes me have to restart Windows 7 when PT9.0.3 crashes.
I'm beginning to suspect this issue is related to PT only being 32bit. Seems like when using some third party VI's PT/W7 runs out of memory.
Another reason to get 64bit PT
Old 12-04-2011, 12:39 PM
TheJamsh TheJamsh is offline
Nope, happens on 64-bit too. I can confirm.
Microsoft Visual C++ Runtime Library error r0binator Windows 1 11-11-2012 07:29 AM
Microsoft Visual C++ Runtime Library. Runtime Error!. C:\program files..Pro Tools.exe moonwalker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-05-2012 10:55 PM
Microsoft Visual C++ Runtime Library error. Dylan360 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-10-2009 03:06 PM
Microsoft Visual C++ Runtime Library Runtime Error OSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-26-2006 05:40 PM
Microsoft Visual C++ Runtime Library Runtime Error OSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-16-2005 08:28 PM
