Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-26-2010, 12:27 PM
goat1927 goat1927 is offline
Default Scrolling Through Presets in Xpand2
Hi there,
Easy question - is there a way to zip through and audition all the presets in Xpand2, rather than having to click and go through menus and mouse clicking?
There has to be an easier way to do this...
Thanks,
Matt
Old 02-26-2010, 01:29 PM
Dorian Green Dorian Green is offline
Default Re: Scrolling Through Presets in Xpand2
I'm gonna try to help you as I don't have my PT in front of me.
First of all choose one preset from the menu on the top of the Xpand2 window.
Then just click on the "double square" button on the top center.
Should appear a new window with the name of the preset within the bank.
You can even set a play loop and set the time at the bottom to change the preset incrementialy, you just have to set the time.
Hope my explainations are not too confusing!
Green Room Studios, France
Mac Book Pro i7 15"4 Mac OSX 10.6.6
PT 9.0.2
DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate.
PTLE 8.0.4
002R Unit and MBox Mini
SSL XLogic Alpha Channel.
SPL Goldmike valve Preamp.
DBX Analog Compressors, Gate and Eq.
Monster Cables
Home made & Neutrik Patchbay.
Brauner, Shure, Seinnheiser and T.Bone mikes.
Tannoy 8D Active monitors.
Old 07-10-2012, 11:06 PM
soybalm soybalm is offline
LOL 2 years later. Thank you!!
Old 04-08-2023, 05:08 PM
ReynaldoPena ReynaldoPena is offline
This is how it used to be
Wth happened?
I also installed Air Music's bundle from AKAI but deleted xpand AAX plug in to reinstall the Air Instruments bundle from My Avid account and still.
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 04-08-2023, 05:32 PM
Ben Jenssen's Avatar
For me, this works:
I select a preset on one of the four, then I can click thru presets with the two small triangles to the left of the preset name.
Old 04-08-2023, 06:16 PM
unkJE's Avatar
unkJE unkJE is offline
There are so many Presets, I’d probably come down with a bad case of “Clicker’s Finger” (RSI) by the time I’d auditioned the lot.
In 2010, Dorian Green showed an easier way:
...First of all choose one preset from the menu on the top of the Xpand2 window.
You can even set a play loop and set the time at the bottom to change the preset incrementialy, you just have to set the time ...
Paraphrasing Dorian:
It’s easier to open Xpand!2 Settings and audition them within the plug-in:
Under ‘Preset’ up top, click the ‘Plug-In Settings select’ button (between ‘+’ and ‘COMPARE’)
Use your keyboard’s Up and Down arrows to audition (and Left and Right keys to change columns)
or
In bottom RHS of Presets, tick the box: ‘Increment setting every’ and select 4 seconds (or other) to audition
If Plug-In Settings are not visible within plug-in:
In Pro Tools Preferences > Display
select: Organize Plug-In Menus By: 'Category & Manufacturer'
For Windows:
Move Xpand!2 from
C:\Program Files\Common Files\Avid\Audio\Plug-Ins
to
C:\Program Files\Common Files\Avid\Audio\Plug-Ins\AIR Music Technology
with all your other AIR Music Technology Plug-Ins
double-click:
Xpand!2.aaxplugin
double-click:
Contents Folder
double-click:
Factory Presets Folder
Copy the Xpand!2 Folder
Paste it here:
C:\Users\Username\Documents\Pro Tools\Plug-In Settings
Restart computer
Launch Pro Tools
Insert Xpand!2 on an Instrument Track
Click the drop-down arrow next to ‘clips’ and change it to ‘notes’
Right-click the ‘Play’ arrow and select ‘Loop’
Add 4 bars of notes, highlight them and hit ‘Play’
Hopefully, Ben will also see this Post and provide the equivalent Mac paths
(Thank you Ben!)
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Last edited by unkJE; 04-09-2023 at 05:14 AM. Reason: ‘Increment setting every’ = make a cuppa while auditioning
which presets in Xpand2? Suke AAX Plug-ins 2 09-03-2013 02:27 PM
XPAND2 missing my patches and presets iamkimosabi Virtual Instruments 1 06-07-2012 11:34 PM
Xpand2 will not play defualt presets sgaree Virtual Instruments 0 10-08-2010 04:06 PM
Changing Xpand2 presets with Axiom pro 61 Sofine Virtual Instruments 7 11-10-2009 02:54 AM
No xpand2 update fixing mouse scrolling through parts ! chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 01-27-2009 06:57 PM
