Old 11-06-2018, 06:27 PM
indeloon85 indeloon85 is offline
Default PT 2018.10 CPU Spikes
I recently upgraded my comp to the new 2018 MBP, which unfortunately comes with the latest High Sierra pre-installed. Since I can roll back to anything I’ve been getting the CPU spikes that Avid talks about being a known issue.
Any chance of getting this bug up in the priority chain for fixing? Super bummer and can be a major workflow killer
Old 11-07-2018, 07:17 AM
samtrino samtrino is offline
Default Re: PT 2018.10 CPU Spikes
I'm in similar situation, Apple replaced a defective 2017 MBP with an 2018 model that came with Mojave...
Pro Tools 2018 was working without a hitch on previous machine, now with Mojave running PT2018.10 I keep getting CPU spikes causing DAE Errors and playback keeps halting at any buffer below 512 - I used to run it at 128 without a problem! (maxed out Mac Pro 5.1 with RME Fireface).
I realize Mojave is not officially supported, and I wouldn't have upgraded myself, but what can we do when we get new Macs with latest OS installed???
I really hope Avid will release a Mojave-supported PT update very soon!
Mac Pro 5.1, macOS 10.13.6, Pro Tools 2018, RME FireFace UFX+
Old 11-07-2018, 07:52 AM
Hi, welcome to the community.
You can ask Apple to provide you with a High Sierra installer download link, if the computer model you have has ever been sold with it. Annoying not to have those links available for everyone, but I guess it's in Apple's interests to gently force people to latest OS
Old 11-07-2018, 08:54 AM
Thanks! Will High Sierra work better than Mojave? The OP seems to be having issue with it as well... it’s a major pain to downgrade to an older version of macOS but it might be worth a try if it works better.
Old 11-07-2018, 09:39 AM
Avid hasn't released Mojave-compatible version yet, so if waiting is less annoying than downgrading you can just bear with it for now
Old 11-08-2018, 04:13 AM
10.14.1 seems to have something done on the CPU throttling, it behaves much much much better on my system than I don't even remember which OS
(disclaimer: on my system means your mileage may vary...)
Old 11-08-2018, 12:59 PM
Cacov's Avatar
Cacov Cacov is offline
Gotta check that out, thanks for the heads up
macOS High Sierra | Apogee Groove & Symphony I/O | Pro Tools 2018
Non-Avid Employee | Sound Engineer
Old 11-08-2018, 01:05 PM
I updated to 10.14.1, it made a small difference on my system, but what made a bigger difference was opening PT in low resolution... much more efficient and smoother overall operation. Now it only occasionally throws AAE error -9173 (while before low res it was unusable).
Old 11-08-2018, 05:29 PM
jjnssn jjnssn is offline
My initial gut feel is the cpu behavior is better on my MBPr 10.14.1. When running down at 64 buffers.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 09:33 AM
2018.7 update fixes the DSP spikes (mac)! bom619 Pro Tools 2018 24 08-03-2018 10:20 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb Pro Tools Software (Mac) 0 06-27-2018 07:33 AM
PT 2018.1.0 CPU spikes energee Pro Tools Software (Mac) 7 04-14-2018 12:13 PM
Pro Tools 2018.1 CPU Spikes anotherone Pro Tools 2018 11 04-10-2018 10:09 AM
