Old 02-04-2012, 01:54 AM
RTASW RTASW is offline
Default Midi import problem, "bad header type encountered"
Hi, seen this mentioned before but can't find any answers. As ever any help greatly appreciated.
I have imported midi data created in Toontrack's Drumtrackerwithout any problem but a friend emailed me a midi file and i just get the above message?
Thanks.
Pro Tools HD Native Thunderbolt, HD IO 8X8X8,ProTools HD 10.3.0 External 1 TB Storage, Apple Mac Mini Processor 2.6 GHz Intel Core i7 Software OS X 10.8.2
Memory 16 GB 1600 MHz DDR3
Old 10-30-2018, 07:23 PM
trkcorp trkcorp is offline
Default Re: Midi import problem, "bad header type encountered"
I have all these MIDI loops you get from here and there and the first time I tried to preview one in Pro Tools (12.8) I had the same issue. I found this work around; it's kinda clumsy buy it works. Go to this website: https://onlinesequencer.net/
It's a bit cryptic but if you click on "Import Midi" you get a dialog to select a file. Use that to get your file imported. Click "Continue". Select the instrument type from the dropdown on the left. (There are 2 & I haven't needed 2 so I select "None, don't use this track". Then click on "Preview/Import".
I haven't bothered with anything else there yet because like yourself; I just want to get the file into Pro Tools so the next step is to click the "Save" button at the right. The last option on that dropdown is "Export". Click on that and get the dialog to point to your desired location and it will put a file there.
You can then drag that file into PT and place it on your instrument track and it will load & play just fine. (Of course you must insert an instrument plugin...) Hope this helps.
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon Pro Tools Software (Mac) 1 02-29-2012 08:03 AM
"Could not complete your request because of an unexpected stream type was encountered milesholmwood Pro Tools Software (Mac) 1 01-13-2011 02:29 PM
Does PT8 do a "Sample to Midi" type thing like Massey DTM? cajonezzz Pro Tools TDM Systems (Mac) 2 01-22-2009 10:55 AM
Try to import mid get "Bad Header Type encountered mfitz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-31-2006 05:28 PM
"bad data encountered while translating midi chunk list" diigi wizards help!! jkriske 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-02-2002 01:42 AM
